pacesetter header
Either need to chop the stock dp right before the cat and have the ball flange welded on, or just have a custom downpipe made. It is not a direct bolt in.
For reference, I had my dp cut and the flange welded on for 25 bucks
Exactly correct, none of the pacesetter items bolt to a downpipe on any application, they are all made this way.
You have to work with the wiring a bit, and work with it, it should be long enough, as they are the same as the 2005-06 setup. If you cannot seem to work with the wiring enough, you could as another option lengthen the wires a bit, by splicing them.
z28addiction
Sep 28, 2015 12:03 AM
