Pcm
Pcm
Okay so I plan to get the zzp stage 3 kit, I would like to send in my pcm first to avoid the refundable core charge. The problem is I'll need to get my car to my buddy's shop to do all the work because he's got the pulley puller, lift and all the other good toys. So I was wondering, can I put the new pcm in before the new parts are installed to drive it a short distance over to the shop? Or will that hurt my car? Keep in mind the canned tune will be for the smaller pulley, new h/e, bigger fuel injectors, etc... I feel like the answer is no I cannot because it will hurt my car but I just want to check.
if you install the new pcm and the fuel injectors at your house you will be able to drive it without any of the other kit parts installed.
So basically if I install the new injectors and new pcm at my house I'll be okay to drive it to the shop without the smaller pulley, new belt, or new h/e? The shops only like 10 minutes away maybe even less.
