PCM question
Old Apr 26, 2009 | 07:09 PM
thatotherguy's Avatar
PCM question
If I replaced mine would i lose my tune??
Does the Pcm deal with AC air condition? mines out. my engine feels hot when i touch the vavle cover after driving to the gas station. idk if all this has to do with that or what.
Old Apr 26, 2009 | 07:18 PM
stage2cobaltss's Avatar
um... if ur gonna use a different pcm then yes u would loose your tune
Old Apr 26, 2009 | 07:21 PM
Oh ok so maybe it would be better to put my stock pulley and injectors in? can i use the wire harness i got now with my 60s on my stock injectors?
Old Apr 26, 2009 | 11:03 PM
Bika's Avatar
Fail Less.
your valve cover is gonna be too hot to touch on any vehicle after a couple minutes of run time. That doesnt have anything to do with your pulley or AC.
Your PCM does control the AC compressor clutch engagement.
No, you cannot use the harness for 60s on GM injectors
Yes you will lose the tune if you replace your PCM
Old Apr 26, 2009 | 11:15 PM
turboecotec02's Avatar
i got a ?. You have all that stuff in your sig and you ask that question. Whats up with that
Old Apr 27, 2009 | 03:47 PM
no u cannot use the harness from the 60's on ur stock injectors different plug ends
Old Apr 27, 2009 | 03:50 PM
koch1ar's Avatar
bought not built?
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
