people running smaller pulleys!!! look here!!
you shouldn't just throw on #60's and a 2.6 and expect it to be ok. you will need to get at least an exhaust, and the h/e, i would do the air box mod too, if you don't have the money for the injen or aem CAI
Doc, some redline newb and I just did a 2.6 ZZP kit install. Yes you have to machine the snout, yes u will get belt slip without an oversized tension or adjustable one with the smaller belt. Takes a while to machine the snout as well so keep that in mind, its a pain in the ass.
Im curious to how the dealership was going to give u the stage 2 tune when you need the code from the stage 2 kit.
machining the snout is a PITA
you should get a second heat exchanger also. that 2.6 pulley will make the supercharger pretty hot i think.
so just hold off the parts until I get there put them on and DOC will give me the tune, is everyone going to try to charge me for putting the parts on there?
z28addiction
Sep 28, 2015 12:03 AM
