pinhole in the brakeline
I am not a mechanic, but I play one on the interwebz.
You must replace a damaged section of brake pipe. You must use steel pipe designed for brake systems. You must use double inverted flare(or ISO bubble) unions to connect your spliced pipe, NEVER use compression type fittings that are commonly used for fuel/oil pipes. Use the proper tools, materials and techniques, if you cant, pay someone who can.
Josh@ottp
Nov 14, 2014 10:41 PM
