Please help, fuel pressure issue.
Old Apr 7, 2008 | 08:09 PM
DrkknightSS99's Avatar
Im not worried about the car blowing up. My concern is why the hell it is not working right now, and even with the "GM Stuff" its not even working well with that either. tomorrow im just going to have them drop the gas tank and have them take a look, it might cost money to have them take a look but at least ill be sound knowing it was or wasnt the pump.
Old Apr 7, 2008 | 10:46 PM
Area47's Avatar
Rent me! per hour
the filter itself on the back of the tank. outside of it. typical gm filter and connectors on it. nothing fancy. lil cylindrical type object hangin out back there.
if the gauge sender itself screwed up and had shown more than actual. i can see that. i don't believe this is the case.
Old Apr 9, 2008 | 11:36 AM
Psykostevo's Avatar
After looking at the tune, it appears that the car "should" be running fine, aside from a rediculously rich commanded AFR, probably designed to allow additional timing, though being counterproductive.
I think that tune would be better suited with a higher AFR and less timing.
Also found it odd that the injector FLOWRATE VS. KPA is exactly the same as the ones I wrote last year........down to every decimal point...........
Old Apr 9, 2008 | 11:46 AM
jekqmb's Avatar
Bad injector? Bad harness connection?
I remember this happening on a Redline, i forget what was wrong with it, ill try to find the thread.
Old Apr 9, 2008 | 03:02 PM
Psykostevo's Avatar
I had a horrible problem with a set of 60's. They worked fine for months, and then all of a sudden one got stuck wide open and it flooded my motor so bad that liquid gasoline came out my tailpipe at idle.
Old Apr 10, 2008 | 04:44 PM
I just got back from the dealer, and it is not the pump nor the fuel filter. The tech checked it along with the tech 2. On the tune that i was given, it does not give any gas for 2nd gear. But when flashed to gm stage 2, even though it runs kinda rich at 10.0 (too rich is 19 he told me and) the car runs, just has a little idle issue, and needs to be hot rodded a bit so the fuel doesnt stay in the cylinder.
Old Apr 10, 2008 | 04:56 PM
Area47's Avatar
Rent me! per hour
we don't have fuel cut per gear.
so yea
got me
Old Apr 10, 2008 | 05:47 PM
Psykostevo's Avatar
did you try putting my tune on there just to see if it worked?
Old Apr 10, 2008 | 05:49 PM
Area47's Avatar
Rent me! per hour
so. he flashed a stage 2 tune on there and you have 60's?
Old Apr 10, 2008 | 06:14 PM
No i did not put in the new tune yet. Dont have my tuner till tomorrow, i will pick up car and will update.
Old Apr 11, 2008 | 05:12 PM
  #36
Well went to go pick it up today, and now the oil pressure light kicked on, having them check that now, heres another week without my car!
Old Apr 11, 2008 | 05:36 PM
  #37
Area47's Avatar
Rent me! per hour
what the **** is going on with your car?!?!?
Old Apr 11, 2008 | 05:44 PM
  #38
well they called me and said it was the oil pressure sending unit so its all good, i thought maybe i blew a head gasket or something lol
Old Apr 11, 2008 | 05:48 PM
  #39
Area47's Avatar
Rent me! per hour
lmao.
i can't help but laugh. seriously. id be looking at other options for vehicles. has the car ever been in a major accident before?
Old Apr 11, 2008 | 06:07 PM
  #40
No i bought it brand new, no accidents, just a scrap that they had to repaint the front bumper for but thats it.
Old Apr 11, 2008 | 06:08 PM
  #41
Area47's Avatar
Rent me! per hour
wow, this is really effed up man.
one of three things will cause that light to come on.
sending unit went bad.
low oil
bad pump.
i wouldn't be quick to jump to a blown head gasket. these motors can take a crap ton of abuse before they fall apart
Old Apr 11, 2008 | 06:13 PM
  #42
yea it ended up being the sending unit.
Old Apr 14, 2008 | 09:00 PM
  #43
06black's Avatar
Hey steve, it was me behind the keybord.
i think we can both agree on the fact that i'm well aware of what i'm doing here
i tried 7 different IFR tables and i was doubling the MAF curve just to get the car to react, nothing was changing, the afr's dident change .2
i put back a BONE STOCK 2006 stg2 tune with the most basic 60lb IFR table and the car was knocking off its ass at 14deg.....
the wicked high commanded IFR in the tune that bryan sent you is due to me just trying to get the car to react to any thing.....
once i heard it was running out of fuel in 2nd later in the day it became apparent that mechanical issues where behind things.
John, i have a few new things i want to talk to you about, and a few new ideas.
Old Apr 15, 2008 | 10:49 AM
  #44
Area47's Avatar
Rent me! per hour
i do have the map that was in the car, because someone was MIA when the lsj went t the doward spiral
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
SlowSaturn
Sep 28, 2015 11:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
