Please help... one more time....
So I got my stage II kit put in before and it seemed like something wasn't right. I was under the impression that my rev limit would be increased to 7k and it seems like it can "chug" a little bit shifting, at least compared to what it used to. When I took it in, I took the sheet with the red and green lines or whatever and told them to take a look at it. I went back to the dealership today and the mechanic said that he tried to find those numbers and did not find it with GM. I am not very mechanically inclined so I had a hard time trying to tell him what was wrong. What should I do?
Originally Posted by wallus13
This dealership really wants to help fix the problem but I don't know how to tell them that they didn't do it right. The head tech guy said that he got the latest update.
GM no longer has the Stage 2 rev limit bumped up to 7000, they came out with a revised flash where the rev limit is back at stock, its been this way for a few months
Hmmm so the "chugging" I get when driving is not related?
Are you even sure they reflashed your computer from the beginning? It might be chugging cause you have bigger injectors in that are spraying much more than they need to be cause of the higher duty cycle. If they reflashed your PCM, then your duty cycle would be lowered so you can idle and cruise at lower speeds better and not have to be in boost to have a decent ride.
Also, if I were you, I'd invest in an Wideband unit...this might save you alot of headaches and curiousities in the future about how your car is running.
Originally Posted by HackAbuse
Update guys!
Yeah I tried to tell them that things should be different but it was the first one they have ever done and they said they got the latest update from GM.
Good luck.
the tech has to call technical assistance and give them your VIN number, and a number off of the instructions that come with the stage 2 kit. technical assistance uploads the reprogram to TIS. thats the only way you can reprogram for the stage 2. if they didnt call technical assistance, they didnt do it right.
Update guys!
I just wrote this down and took it in and they got it fixed. It runs GREAT now. Thanks to everyone who helped, I am happy with the upgrade now.
Enjoy the car
