Popped dipstick, engine covered in oil!
Old Sep 18, 2006 | 03:26 PM
BradyB's Avatar
Dab nab it!
My belt was squeaking a little bit and so I popped the hood. To my surprise there was oil all over the passenger side of the engine bay! I freaked out for a bit looking for holes in the engine block but then I realized the dipstick was just sitting their loose.
Did I hook up one of the three lines wrong that you disconnect to install the stage II kit, or was there just an idiot at the dealer that forgot to push the dipstick in all the way when the car was serviced?
I've seen turbo cars that would pop out their dipsticks after the crank case become pressurized (i.e catch cans) but I never thought a factory S/C car would have that problem. I'm only running 12 PSI too! Any suggestions or past experiences?
Thanks!
Old Sep 18, 2006 | 03:28 PM
patathSS's Avatar
Pictures!!!
Old Sep 18, 2006 | 03:34 PM
BradyB's Avatar
..sorry no pics. I grabbed a stack of napkins and wipped off everything I could get to. I'll pick up a bottle of parts cleaner on the way home and try and clean of the front of the engine.
By the way guys, this is the same dealer that forgot to screw back on the radiator fill tight and I lost most of my radiator fluid until the idiot light popped on. I had to stop at the first gas station I could find and hurry and add some generic stuff. They just flushed the system and filled it back up with Dexatron on Friday, I wonder if they checked the oil too and left the dip stick loose?
What you think?
Old Sep 18, 2006 | 07:55 PM
BradyB's Avatar
bump.... any seen this on one of our cars?
Old Sep 18, 2006 | 08:00 PM
TheYellowSS's Avatar
yeah, it might just have been forgoten and didnt get put back in. i run close to 17 psi and ive never had a problem. about the oil i would go to pep boys or autozone or a local auto store and get some engine degreaser, take it to a power wash. lather the entire engine with the degreaser, make sure u keep the engine running and then power wash the degreaser off the engine. If it happens again, you can pinch the tube just a little, not to much or it wount seal. but just enuff to create more brip on the washer
Old Sep 18, 2006 | 08:04 PM
Jekyl's Avatar
happened once to me at the track while making a run.
I just popped the dipstick back in and it was fine.
Old Sep 18, 2006 | 08:14 PM
p7x's Avatar
p7x
O YA!!!
happen to me twice. U can try taking into the dealership and have them check, the PCV system, oil filter as well as the intake. There's too much crankcase pressure and Im still not certain why it happens but after they replaced the "intake manifold" is hasnt done it since.
Old Sep 18, 2006 | 09:07 PM
eastcoastz's Avatar
Yea its a strange because I did not have this problem until the dealer replace my head. After the head was replaced it happened all the time. After a few weeks it just stopped.
Old Sep 18, 2006 | 09:15 PM
06CobaltssOrange's Avatar
hey
my dipstick popped off but i think it was put on like a bitch and very little oil spilled so i just popped it back on havent had a prob since!
zinner's Avatar
Moderator Alumni
Yep I have read threads like this before.
Old Sep 18, 2006 | 09:25 PM
8cd03gro's Avatar
what the hell happened to your head?
Old Sep 18, 2006 | 10:02 PM
eastcoastz's Avatar
I happened! I've been driving manual for for 9 years and then back in April I was raacing and tried to go into 3rd and it just would not engage so I RAMED it into what I thought was third gear WRONG it was first. The engine must have hit like 10k rpms! Well it still drove and idled smooth, but it had no power and the exhaust sounded just like a WRX with a turbo back. Three Chevy dealers told me "ahh yea theres nothing wrong that we can." So I took the valve cover off just to see if anything broke and there were 3 shattered lifters, 3 roller rockers layin in the head and the cam and head were galged where one of the rockers was caught between the cam and head.
Old Sep 18, 2006 | 10:06 PM
BlueSS-supercharged's Avatar
uhh damn that sucks man^^
Old Sep 18, 2006 | 10:12 PM
eastcoastz's Avatar
Its all good they covered it on a one time good will deal at the daeler. Of coarse I didn't tell them I overreved the **** out of it.
Old Sep 18, 2006 | 10:22 PM
JonyyB's Avatar
Site Founder
This happens with stage 2 all the time. Do a search for a bunch of threads like this
Old Sep 19, 2006 | 03:15 PM
BradyB's Avatar
So it does happen, if it happens again I'll have the dealer check her out with some suggestions.
I could always install a switch valve off a manifold line that flips open with boost and a catch can. I'll reserect this thread if something happens again.
Thanks Guys!
Old Sep 19, 2006 | 03:24 PM
CTCOBALTSSS's Avatar
Yea it does. It happened to me while I was on the dyno of all places. Not cool. Good thing it didn't make a huge mess and it happened right at the end of the first run. I was like WTF something blew up I knew this was going to happen but it ended up being the dipstick.
Old Sep 20, 2006 | 12:54 PM
John's Avatar
What you think?
im leaning more to that the dealer forgot to put it back in
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
SlowSaturn
Sep 28, 2015 11:03 AM
