porting and polishing the blower..got ?s
Old Nov 30, 2006 | 12:42 AM
distillion's Avatar
im thinking of doin this, the shop i deal with will send it out for me and when it comes back it will be shiny and ported by stegmier(mind the spelling)
my concern is that i have a bunch of mods plus a custom reliable tune with a 2.85 pulley and 42's now if i do this to my blower do i have to worry about idc's all over again cuz i really dont wanna switch over to 60s since this will probably one of my last big mods performance wise, thanks.
Old Nov 30, 2006 | 12:43 AM
R&C_rallySS's Avatar
That is a really good question. I will be checking this thread out waiting for an answer. I'm in the same process. IMO I do not think it will change much of anything.
Old Nov 30, 2006 | 01:11 AM
Pooch's Avatar
i don't think your gona gain much per say by doing the port/polish. but i think it will help smooth out the HP and TQ curves of the car.
But i may be wrong.
Old Nov 30, 2006 | 07:49 AM
BlackyK's Avatar
I don't see it has being too big of a deal. All you're doing is just opening up the blower, the augers still are spinning at the same rpms. So you'll have less boost because there is more space for the air.
Old Nov 30, 2006 | 08:25 AM
distillion's Avatar
hmm, is there anyone that has done this with before and after gains?
apparently stegmier is well known for there porting of blowers, like i said its in the air right now, the car is fast enough, just wondering what the gains would be and if i did go this route would the injectors still work at a safe rate?, jim, my setup includes a smaller pulley(2.85) full exhaust, intake, 42's and a tune.
Old Nov 30, 2006 | 08:37 AM
HiSpdPursuit's Avatar
Who better to find out about Eaton Supercharger porting than the biggest customers for it....the mustangs and lightning crowd. And YES i know they are v8's but it is generally the same rule of thumb.
http://www.fordmuscle.com/archives/2...ting/index.php
http://www.mustangforums.com/m_1323567/tm.htm
http://www.musclemustangfastfords.co...ed_eaton_swap/
there is more info out there on this...especially in the lightning forums
Old Nov 30, 2006 | 08:41 AM
Originally Posted by Jim@Tagracecraft
Spend the Money Elsewhere .The porting is a waste of hard earned money .
Are you porting the blower for looks or performance ?
If it's for looks great ...But performance ..Nothing is really going to be gained
A better choice would be a smaller pulley and injectors in my opinion.
There are a few threads out there to support what i have said .
wrong...used in conjunction with a smaller pulley and injectors (what he already has) is well worth it. He can maintain the 2.85 pulley and 24.5# injectors and get the charger ported.
I dunno what you are talking about...but i would much rather have a good sized pulley not overspinning the charger, but still making better efficiency and power at less boost then a smaller pulley would.
Old Nov 30, 2006 | 11:20 AM
Show Me some Hard Facts on the m62 ported Blower and cobalt
Dyno sheets Please.
The Larger Blower and this aren't the same animals
Regardless It's Distillions money
What does the size of the supercharger have to do with anything? the general rule of thumb is the same...If you increase the Cfm it can pump by porting it out then you end up with greater flow with lower boost which in turn means better efficiency and less heat.
your logic was to just slap on a smaller pulley and feed it more fuel....so lets add more parasitic drag on the crank for a couple more pounds of boost and higher temps....great job.
Old Nov 30, 2006 | 11:23 AM
DWK5150's Avatar
There was a memeber on redline that did before and after dynos and gains were minimal meaning only a couple HP. Mine is ported weather or not I gained anything I couldnt tell you as I dont use dynos.
Old Nov 30, 2006 | 11:26 AM
in all honesty...we will never know how much there is to gain doing it on these cars until someone does it. its basically uncharted territory. but in general for other cars porting the eaton supercharger has yeilded decent gains and better efficiency.
Old Nov 30, 2006 | 11:44 AM
Bad06SS's Avatar
What I want to see is the difference in IAT2's. Even if the blower wasn't worth but 2-3whp, if it makes it a little more efficient, that matters to me. These 2.5" pulley's create alot of heat! Maybe it could help prevent blower heatsoak?
Old Nov 30, 2006 | 11:45 AM
distillion's Avatar
another good point.
even though my pulley is not that small im sure it wouldnt hurt.
Old Nov 30, 2006 | 12:12 PM
shabodah's Avatar
rlinbatonrouge is the guy who had the dyno's done, but they weren't an exact comparison, because he had one blower with a 3" pulley, unported, and one with a 2.8" that was ported. Regardless, the differences between the two were approx 12 horses and 7 ft/lbs or so. His car was pretty much stock other than the blower and stage 2 equipment at the time. My blower is also ported, but I too, have not dyno'd. Everything seems to point to this as having minimal gains, but I'd venture to say, the faster you spin the blower, the more it will help. Also keep in mind that the throttle body and intake can be restrictions that can negate any gains from the blower if they are not handled.
Old Nov 30, 2006 | 12:25 PM
badboylb32's Avatar
Why dont you just get the outside polished for looks? Thats what im doing. Im not gonna mess with porting it until i know for a fact everythings gonna turn out good.
Old Nov 30, 2006 | 12:50 PM
either way porting your blower WILL show gains...maybe small HP or Torque gains...but it will also become more efficienct for sure, creating less heat which is also a good thing.
I think the only real question here is bang for the buck...
Old Nov 30, 2006 | 12:57 PM
DWK5150's Avatar
Intense does offer the proted housing for less than steigmeir does I think.
Old Nov 30, 2006 | 02:07 PM
You mean 42.5 injectors? Anyways, agree with its the bang for buck thing. Gaining 2-3hp and 2-4 torq with a port and polish job on the M62 is only worth it if you have alot of cash to throw around. That cash could be put towards something else more worth it. Then again, if it makes it more efficent and looks great why not? Again though, any proof on any gains or effiency?
Old Nov 30, 2006 | 02:12 PM
yea i meant 42.5....sometimes im dyslexic. As far as proof on these cars there really is none because it really hasnt been attempted. But the SVT Cobra and Lightning crowd has posted some pretty impressive gains upwards of 30-50 hp and 12-15 tq depending on the job...yes they have twice the engine so the gains wont be as good...how much the 2.0 would gain is really only to be determined if someone does it.
Old Nov 30, 2006 | 02:15 PM
I wish I had a dyno after each mod. I just can't do that cuz that would be very costly. If only I had my own dyno I would so do the testing. Port & polish the supercharger, also port and polish other things like head, and intake manifold. Should help out.
Old Nov 30, 2006 | 02:16 PM
Bad06SS's Avatar
Well, a buddy stated that he saw a 10-12 degree DROP in his IAT2's after the ported blower, that alone would be worth the $300.00 in my opinion (atleast at my mod level). Any power/torque gains after that would just be a bonus. I think real results won't show up untill a small pulley like 2.5"-2.6" (or a 2.8" if you have a 8,000rpm redline).
Old Nov 30, 2006 | 02:25 PM
shabodah's Avatar
Put the money towards a TVS swap next year. That'll bring much higher gains, and then you can have the TVS housing ported later.
Old Nov 30, 2006 | 02:36 PM
That would rock! Thing is though, I'm going as fast as I can go with GMP parts. Which means no swapping a super charger. But that would be awesome after my 7 year 75k mile warnity is up.
Old Nov 30, 2006 | 02:44 PM
phlatcav's Avatar
mines out getting ported and exterior polished as we speak. I do plan to dyno after i get it back se we will see. Granted gains will be diff as I have a 2.2 so who knows.
Old Nov 30, 2006 | 04:16 PM
Can't wait to see. Keep us up to date man!
Old Nov 30, 2006 | 04:24 PM
Blown 4-banger's Avatar
Someone get Shortbus in here!!! I've been thinking about porting it as well, I'm pretty sure Shortbus ported his.
