Possible New Setup
Old Sep 6, 2011 | 02:54 PM
spchrgd's Avatar
Possible New Setup
Hey guys, So Im almost ready to take the next step and get a stage kit.
As of now, my car is totally stock other than: zzp 3" intake and zzp stage 3 heat exchanger. I am running stock exhaust also.
This is the setup I was thinking about:
-zzp tune
-oversized tensioner pulley
-gm shorter belt
-60# injectors
-2.9" pulley (possibly 2.8")
Let me know what you guys think, I'm still pretty new to everything so just wanted to make sure I was headed in the right direction.
Thanks a lot for any help/suggestions!
Old Sep 6, 2011 | 02:57 PM
sjc0013's Avatar
Window Licker
Looks like you're headed in the right direction to me! And guys correct me if I'm wrong but you shouldn't need the tensioner pulley if you get the shorter belt
SlowCobaltSS's Avatar
Opition B reservoir dual by pass endplate and if you go with the oversized tensioner pulley you dont need the shorter belt the stock belt will work
Old Sep 6, 2011 | 02:59 PM
sjc0013's Avatar
Window Licker
Yeah this lol, or vice-versa
Old Sep 6, 2011 | 03:00 PM
Originally Posted by sjc0013
yeah this lol, or vice-versa
lol
Old Sep 6, 2011 | 03:01 PM
carstedt's Avatar
sounds like a good start
sjc0013's Avatar
Window Licker
Oh **** and I see you are from Lancaster! What up man! haha I am from York
Old Sep 6, 2011 | 03:31 PM
Bluelightning's Avatar
Got Bewst?
I went to use an oversized tensioner from ZZP when I bolted up my 2.6" pulley and it rubbed on the bottom of the tensioner itself. Apparently it needs modifying to fit. I just tried it without the oversized tensioner and just the GMS2 belt and thankfully no slip so I didn't bother with it
Old Sep 6, 2011 | 04:22 PM
spchrgd's Avatar
Alright, so either the shorter belt or the oversized tensioner pulley. Has anyone else used the zzp tensioner pulley??
Also do you guys think the dual pass endplate is needed for now? I will probably eventually get one....
No way! I actually go to school at York College of PA, thats where I'm at right now!! haha
Old Sep 6, 2011 | 04:57 PM
I would just spend the extra 80.00 for the dual by pass because your going to need cooling mods for the more boost pressure
Old Sep 6, 2011 | 05:41 PM
sjc0013's Avatar
Window Licker
No **** man!!!! My best friend goes there, he drives a bright yellow ford focus with a body kit and black rims. Also have another buddy who goes there and drives a black ss with a low rise wing.
Old Sep 6, 2011 | 06:31 PM
spchrgd's Avatar
^^^ nice dude! Ill keep an eye out.
So you dont think the s3 heat exchanger is enough? Im running it in parallel with the stock h/e currently....
Old Sep 6, 2011 | 06:49 PM
Got Bewst?
All a dual pass, and heat exchanger will do is recoupe your IATs faster after a pull. It will not actually lower IATs during a pull. So IMO it is not needed unless you like to do back to back pulls all the time
Old Sep 6, 2011 | 07:15 PM
sjc0013's Avatar
Window Licker
Youre good with the s3 man, no need for dual pass unless you're gonna run a crazy small pulley
Old Sep 6, 2011 | 07:37 PM
The reason that I said anything to him about a dual bypass end plate is because the way that he's doing stuff to this car he wanted the car to be alot fast and once he gets the extra power he's looking for I can tell he's going to be out running people one right after another
And the IAT's will be lower with the daul bypass end plate and the ZZP S3 H/e and thats what you want...You dont want ur IAT's to high
Old Sep 6, 2011 | 07:48 PM
spchrgd's Avatar
Alright thanks guys...I probably will end up getting the end plate once I have extra money, just wanted to make sure it wasnt extremely bad to run without it.
Old Sep 6, 2011 | 07:53 PM
sjc0013's Avatar
Window Licker
Yeah you're good to go, you'll be fine until you save up the extra cash, another wise investment is an interceptor, that way you can monitor your iats
Old Sep 6, 2011 | 08:04 PM
spchrgd's Avatar
Yup, that's on the list too....so many things, so little cash!!!
Old Sep 6, 2011 | 08:07 PM
sjc0013's Avatar
Window Licker
Yeah man I feel ya
slawson0042's Avatar
my 2 cents..
s3 HE, Dual Pass, Stg 2 belt, Overszed tensioner
then throw on the 2.6 and watch that boost gauge tach out. thats what I had on my car anyway. I loved it.
Old Sep 6, 2011 | 08:33 PM
jonathan923's Avatar
sounds like a good start, just make sure you have a good tuner. never go with zzps canned(shitty) tune though
Old Sep 7, 2011 | 03:50 PM
spchrgd's Avatar
2.8 or 2.9 with this setup??
Old Sep 7, 2011 | 04:28 PM
Boosted05's Avatar
honestly 2.9 without exhaust mods, 2.8 with. I have a bad mab header, and zzp 2.5 DP and still see 18 psi at the top of 2nd/3rd gear.
I have the ZZP tune, and depending on which they are sending out now it's not bad at all..... I'm getting great mileage on mine, and awesome power. Mine was a new one Tim had done, built around the Injen CAI, since I had the K&N we used that one and it worked out I was damn near dead on for fuel trims and such.
Old Sep 7, 2011 | 05:06 PM
spchrgd's Avatar
great input, thanks
Old Sep 7, 2011 | 09:10 PM
Got Bewst?
Holy crap you sure your cat isn't clogged? I'm on a 2.6" pulley and running meth through my blower which bumps up my boost about 2 psi and i'm running 19 psi. spchrgd IMO just go with the 2.8" I ran a 2.8" all summer last year with stock exhaust. 2.9" to 2.8" is not going to make or break you needing exhaust mods at all. And will give you a little more seat of your pants pull.
