powell tow hooks
Old Mar 16, 2012 | 03:29 AM
Melon's Avatar
powell tow hooks
ok so i have a question regarding these. i am looking to start tracking my car and need/want to get tow hooks. the question i have is how many of u guys that r using these have actually had to use them? meaning actually have ur car towed. my main concern is i heard there r some out there that r purely cosmetic and will rip right off. heard a lot about these and just wanna make sure thats not the case. also has anyone installed these with the zzp heat exchanger, does it fit? thanks in advance everyone!
Old Mar 16, 2012 | 03:31 AM
heathkidder's Avatar
i have the zzp h/e and tow hook if you put it directly in the middle itll fit if you put it to the side like i did i couldnt use the spacer so it almost hits the top piece of the bumper. iv seen pics of ppl actually using these there bolted to the frame i dont see why they wouldnt work.
Old Mar 16, 2012 | 03:34 AM
Melon's Avatar
do u need to use the spacer? thanks for the info! good news so far
Old Mar 16, 2012 | 03:35 AM
SKCobalt's Avatar
I'll let the guys that have them confirm this, but the Powell tow hooks are tested and are a functional piece and not just for aesthetics.
As for installing the hook with a zzp heat exchanger, i'm not sure if you will run into any clearance issues when bolting it to the crash bar. I would say that would depend on how far your heat exchanger is set back on the crash bar.
Old Mar 16, 2012 | 03:37 AM
well i can post pics of what im talking about and no the spacer plate doesnt need to be used. but its used to clear the bumper but mine barly touches it so i didnt mind. my zzp h/e upper bolts bolted in the same place i wanted the tow hook since the crash bar is curved and not straight thats why i said it will fit just fine in the center of the bumper but if you put it to the side since the crash bar curves you will run into issues.
Old Mar 16, 2012 | 03:40 AM
Old Mar 16, 2012 | 03:44 AM
Melon's Avatar
sweet! thanks for the pics!
Old Mar 16, 2012 | 03:45 AM
as you can see theres not enough room for the spacer so i just used it without. only way you could use it is where i have the bolt use the back hole in the spacer and you would have to trim a small piece from your bumper
Old Mar 16, 2012 | 03:50 AM
Melon's Avatar
if the spacer isn't neccessary then i would just run that and not worry about trimming anything
Old Mar 16, 2012 | 04:13 AM
HB_SS/TC's Avatar
Just use the spacer and install it in the middle
And yes these do still work after a 60+ mph crash
http://www.youtube.com/watch?v=CttJJ...e_gdata_player
Old Mar 16, 2012 | 04:50 AM
Melon's Avatar
thats awesome advice and evidence! i'm sold!
Old Mar 16, 2012 | 06:44 AM
Powell Race Parts's Avatar
good pictures and install. I recommend a little never seize for the stainless through bolt to void rust in the pivot, we now pc in the tube to try and slow down the dreaded "R" word lol
thanks for choosing genuine Powell hardcore Race Parts!
we got lotsa colors,as well as regulation red....
Old Mar 16, 2012 | 01:30 PM
keiserX13's Avatar
This
Originally Posted by YelloEye
I can vouch for the sturdy construction of this piece, towed a V10 F250 ~500ft up a short hill with my rear hook. Also bent my rear bumper a tad trying to pull a fallen tree https://www.cobaltss.net/forums/5851948-post144.html
Old Mar 16, 2012 | 02:34 PM
Melon's Avatar
perfect. thanks for all the input guys. i know wut i'm ordering next pay day....
Old Mar 16, 2012 | 02:56 PM
mkulrey13's Avatar
I love my hooks!
Old Mar 16, 2012 | 03:09 PM
alleycat58's Avatar
Check if your track has color requirements. Red works anywhere, some tracks don't have a requirement, some will also accept yellow, some just require that it NOT be certain colors that are hard to see.
Old Mar 16, 2012 | 04:00 PM
Blowncavy's Avatar
Have any candy purple hooks?
Old Mar 16, 2012 | 06:16 PM
paddock's Avatar
They are EASY to install ... and work VERY well.
I've, unfortunately had to use them and they worked phenominally!!!!!!
Old Mar 16, 2012 | 10:04 PM
Melon's Avatar
mkurley, how do u mount ur plate like that? i'm lookin at doing the same setup. i'm gonna get blue but keep red duct tape on me just in case. lol
Old Mar 16, 2012 | 10:11 PM
keiserX13's Avatar
Amazon.com: Show N Go License Plate Holder: Automotive
chefhhr
Oct 26, 2015 10:36 PM
OrangeCoba
Oct 1, 2015 10:00 PM
nathan112i
Sep 30, 2015 07:12 PM
