Power Cable Arched PCM
Old Jan 4, 2011 | 11:40 PM
blazinraign's Avatar
The battery cable arched the PCM, the cable was unplugged from the battery, but still arched. Car will not start now, is the PCM bad?
2006 Cobalt SS
Old Jan 4, 2011 | 11:45 PM
Chevycobaltss3's Avatar
if it arked check all fuses and relays like say battery fuse, the ip fuse crank fuse and ect, the pcm has a capacitor that should hold most arc but not all ive seen some pretty pcms burned, just make sure to check all before ordering a new one.
Old Jan 5, 2011 | 12:03 AM
I checked all of the fuses under the hood, i pulled up each one of them and nothing was blown, all the fuses in the interior as well, nothing blown. The battery fuse? The one in the trunk? what wasn't blown either.
Everything in the interior works. I turn the key over, car does nothing, please help..
Old Jan 5, 2011 | 12:05 AM
disconnect pcm look at the biggest connector on the pcm if it dont smell or its not dark reconnect it and see if the car will start.
if you want to call me if this dont work my nameis james and tele is 270 505 3212
Last edited by Chevycobaltss3; Jan 5, 2011 at 12:05 AM. Reason: Automerged Doublepost
What relays should i check?
Old Jan 5, 2011 | 12:08 AM
u have a crank relay, and that should be it ... two of them in the hood fuse box, also make sure your car doesnt have the pass lock system engaged when the car is on in the on position theres not supposed to be the little lock on it it should come on then off if it stays on then pass key is engaged and you need to do the relearn
Old Jan 5, 2011 | 12:19 AM
OK, I felt one relay click, one didn't, the pass-lock is not engaged, i thought about that as well. the lock box is is not on.
Thanks for all your help.
Old Jan 5, 2011 | 08:08 PM
Fixed, PCM ground in the wire harness was burned. Ran a new ground and It Started! James is awesome!
/end thread
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
Stuff
Oct 1, 2015 05:47 PM
footballplaya3k
Sep 30, 2015 09:39 PM
