Power source for gauges?
Old Jun 29, 2012 | 09:52 AM
sujomatt's Avatar
Just curious where u guys tap into? I can't seem to locate a spot to get some power to my wideband. Please help asap!
Old Jun 29, 2012 | 09:56 AM
user 72239's Avatar
OBD2..LIKE A BAWS
Old Jun 30, 2012 | 10:01 AM
rivaladore's Avatar
I've tapped into the power wire for my stock boost gauge. I've also used an "add a fuse" circuit on the ignition fuse to wire up another members wideband. There's also a fuse panel inside the cabin by the passengers feet on the left, but haven't taken a look to see what fuse you can tap into. Didn't know that was there until recently or I would've used the add a fuse somewhere on that panel.
Old Jun 30, 2012 | 10:48 AM
evilution's Avatar
I had my fuse box apart, and used one of the unused fuse slots and ran a wire from there, then branched it out to each of my gauges...but an "add a fuse" would work great too. I used an add a fuse to hook up my IC pump off an ignition sourced device (I think I tapped into the fuel pump fuse). Lots of options if you use an add a fuse, just pick something that's key on/ignition and you'll be good.
Old Jun 30, 2012 | 10:54 AM
BlackARCA06's Avatar
Add a fuse is prolly the easiest, I used the windshield wiper fuse since it only comes on when the car is on.
Old Jun 30, 2012 | 11:00 AM
nhanson's Avatar
Add a fuse on the injector fuse
DarrenGC
Dec 24, 2021 01:55 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
Stuff
Oct 1, 2015 05:47 PM
