Prob asked a million times but
Old Apr 13, 2009 | 04:41 PM
Caligula's Avatar
What can I get for an Sc that wont void anything.
I have stage 2, and a exhaust.
I know they have a monifold
Any Hp add there?
Old Apr 13, 2009 | 04:44 PM
Tank07's Avatar
cold air intake
and a tune
Old Apr 13, 2009 | 04:46 PM
Caligula's Avatar
Sorry, Im new to this car thing, never had a good car to work on before the cobalt.
Whats a tune?
Old Apr 13, 2009 | 04:47 PM
red06SC's Avatar
Originally Posted by Tank07
cold air intake
and a tune
one of these will void a powertrain warranty, one will not
just get an intake if you're concerned with keeping it
Old Apr 13, 2009 | 04:49 PM
ssyellow's Avatar
um...well its a tune changes the computer and such for more hp and you can change A/F ratios like when you change pulleys or injectors
Old Apr 13, 2009 | 04:50 PM
Tank07's Avatar
not true at all.........u can get a reflash when u need to bring it in for warranty work
a tune is just reprogramming you ECM to get more out of it....
Originally Posted by ssyellow
um...well its a tune changes the computer and such for more hp and you can change A/F ratios like when you change pulleys or injectors...u got a s/c or n/a?
reading is > you jk
hes got a sc
Old Apr 13, 2009 | 04:51 PM
red06SC's Avatar
reading is > you jk
hes got a sc
And your dealer can see that it has been flashed. Warranty = void.
Caligula's Avatar
06 sc
Old Apr 13, 2009 | 04:56 PM
ssyellow's Avatar
dammit I know!! lol right after I posted it I was like ..**** he said he had stage 2 lol my b
Old Apr 13, 2009 | 04:57 PM
Tank07's Avatar
this is false..........plus they do not look for these things.......they hook it up to a machine and see if it passes the tests and if it does they work on it
this is per a mechanic at a local nissan dealarship........he has no reason to lie about that
SCcobaltSS's Avatar
Actually the dealer can void your warranty for an intake. My buddy blew his engine and they said it was because of the after market intake.. lol
Anything that the dealer installs they will more than likely warranty, it is expensive but if you are worried, thats what you have to do.
ECM flash will void you warranty too.
Tank07's Avatar
he also works in a chevy dealershop as well
so take the intake off before you go in for warranty work?
Old Apr 13, 2009 | 04:59 PM
Brenticus's Avatar
warrenties are not voided due to aftermarket parts unless the parts were the cause of the damage.
sport08's Avatar
intake and cat-back exhaust is all u can really do and keep ur warranty. a tune WILL void your warranty if they find it.
Old Apr 13, 2009 | 05:02 PM
Tank07's Avatar
if they find it........which they wont if you flash it back to factory before you bring it it.....
Old Apr 13, 2009 | 05:03 PM
sport08's Avatar
i forget what there sn was but there was a post about GM that stated that GM is going to start checking cars for tunes that come in for warranty work. it was someone who works for GM i think it MIGHT have been Maven im not sure though
red06SC's Avatar
No, they can still see that the ECU has been flashed.
Old Apr 13, 2009 | 05:05 PM
Tank07's Avatar
where did you get this info?
scratch last post.........im 99% sure though this isnt the case.......like i said i have a family friend that works at a stealership and helps me with my car all the time when i run into jams..........he said they will not look for it at all, and cannot tell if its been reflashed
sport08's Avatar
i heard they can find that it was reflashed and find out that it was tuned.
red06SC's Avatar
#08-06-04-033: Identifying Aftermarket Engine Calibrations 2.0L, 2.2L, 2.4L, 2.8L, 2.9L, 3.0L, 3.1L, 3.2L, 3.4L, 3.5L, 3.6L, 3.8L, 3.9L, 4.2L, 4.3L, 4.4L, 4.6L, 4.8L, 5.0L, 5.3L, 5.7L, 6.0L 6.2L 7.0L, 7.4L, 8.1L Gas - (May 30, 2008)
Subject: Identifying Aftermarket Engine Calibrations 2.0L, 2.2L, 2.4L, 2.8L, 2.9L, 3.0L, 3.1L, 3.2L, 3.4L, 3.5L, 3.6L, 3.8L, 3.9L, 4.2L, 4.3L, 4.4L, 4.6L, 4.8L, 5.0L, 5.3L, 5.7L, 6.0L, 6.2L, 7.0L, 7.4L, 8.1L Gas Powered Engines Only
Models: 2006-2009 GM Passenger Cars and Light Duty Trucks
2006-2009 HUMMER H2, H3
Excluding Pontiac Vibe, G8, Chevrolet Aveo, All Saturn and Saab Models
Important: This bulletin applies to Gas Powered Engines ONLY. For Diesel Powered Engines, refer to Service Bulletin #08-06-04-006A.
If a suspicious hard part failure is observed in the engine, transmission, transfer case or driveline, perform the calibration verification described to determine if a non-GM issued engine calibration is installed. Non-GM issued engine calibrations subject driveline components to stresses different than the calibrations which these components were validated to. Repairs to transmission, transfer case and/or other driveline components where a non-GM engine calibration has been verified are not covered under the terms of the New Vehicle Warranty.
Instructions for Confirming Calibration Verification Number (CVN):
Go to TIS2WEB
Select "Calibration Information (SPS Info)"
Enter VIN
Select "Get Cal ID"
Select "ECM Engine Control Module"
Select "Next"
Select "Complete History"
Print
Take the printout to the vehicle along with the Tech 2Ž
Plug in the Tech 2Ž
Go to diagnostics and build the vehicle
Select "Powertrain"
Select "Engine"
*Select "Engine Control Module" or "PCM"
*Select "Module ID Information" or "I/M Information System" if module ID information selection is not available.
*If "I/M information System" was selected in step 15, it may be necessary to select "Vehicle Information" in order to display the calibration information.
Compare the calibration ID and Calibration Verification Numbers (CVN) to the Calibration Verification Numbers (CVN) on the printout.
* Steps may vary by controller.
Although the part numbers will be the same for each, it's the CVN that will determine if the calibration is GM issued. If ALL of the CVN's are EXACTLY the same, the calibration is GM issued.
If the part numbers match and ANY CVN's DO NOT match the printout, it is likely that a non-GM certified calibration has been installed.
If the CVN information is displayed as "N/A", it will be necessary to contact the TCSC to obtain the CVN information.
If a non-GM calibration is found to be in the ECM (CVN's on the Tech 2 do not match TIS printout) - In order to document the case -- a CLEAR digital picture should be taken of the Tech 2Ž screen showing the VIN and the CVN's that do not match the TIS2WEB printout. The picture, VIN and reason the vehicle is currently in for service should be emailed to and for verification. Please copy your GM District Service Manager (DVM) on the e-mail. GM will verify if the CVN's are not GM issued and respond via e-mail within 72 hours.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Š 2008 General Motors Corporation. All rights reserved
You can't flash an exact GM tune, you can just set the same parameters. The numbers will be off.
Old Apr 13, 2009 | 05:07 PM
Tank07's Avatar
if u rele need the warranty and rather be safe then sorry dont get the tune
u can save the orignal file from the car..
sport08's Avatar
thats what i was thinking of thank you for finding that
Old Apr 13, 2009 | 05:08 PM
red06SC's Avatar
HPT can not reflash under the same serial numbers or some nonsense like that. It will be a GM tune, but it will be labeled differently.
Old Apr 13, 2009 | 05:09 PM
Tank07's Avatar
well thanks for clarifying that lol
so just stick with the intake OP
Old Apr 13, 2009 | 05:10 PM
Caligula's Avatar
Yeah, Im not gonna risk voiding it.
So i'll stay with the intake.
And take that off whenever I take it to GM for anything.
