Problem with heat exchanger
Old Apr 8, 2010 | 09:47 PM
BLUE TRANSFORMER's Avatar
The past few days I noticed a small leak around the bottom valve. Upon investigation I noticed that there is a arm that gets knocked around on driveways parking curbs etc.
Can this be replced with something smaller? What mixture are you guys running. coolant/water mix ratio..
Old Apr 9, 2010 | 08:46 AM
rollingboostedss's Avatar
I run a 75 to 25 mix in mine ratio
Old Apr 9, 2010 | 08:54 AM
BLAZIN07SS's Avatar
I'm too JDM for you
you can just put a bolt in there instead if you like. and i am currently running straight distilled water with some water wetter
Old Apr 9, 2010 | 03:53 PM
Hey thanks for replying guys. Blazin and Rollingboostedss. Blazin since were in the same area what are your coolant temps... Mine went up to 188 I average 174 to 179..
Old Apr 9, 2010 | 03:55 PM
BLAZIN07SS's Avatar
I'm too JDM for you
well remember coolant temps are different from the supercharger cooling system(Intake air temperature 2 sensor reads this) temps. either way i have my fans kick on real early. my car never gets above 174*F COOLANT temp.
DarrenGC
Dec 24, 2021 01:55 PM
n20saturn
Sep 30, 2015 12:26 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
