Problem HELP with H/E
ok so i got my car back today and im having problems keeping my car under 195 coolant
I order this h/e
this is the one i got http://www.rpmoutlet.com/03cobraheat.htm
how is it supposed to be like install like which hoses got where? theres on hose going to the punp and the other one is going to my stock h/e for some reason. the guy put it on and that way and i need to know where the hoses go.
and i already read that thread about how to installing the h/e but mines different than everyone elses
I order this h/e
ok, first off, if you are going off your coolant temp on your gauge panel, then you are looking at the wrong thing. You should be looking at your IAT1 and IAT2 temps. The only way to see them is logging with hptuners or getting an aeroforce scan guage.
secondly, if you want to know how to install h/e's and what parts you need to do it, then you need to search. There are a **** load of threads on h/e's and there are a couple different write ups on how to install cobra h/e's and other ones. Just search.
