problem with timing
Old Sep 2, 2008 | 07:41 AM
heyitsmikey1987's Avatar
problem with timing
i went to get my car retuned after adding a cobra heat exchanger and methanol and i can only hit 12 degree it i try to go any higher i get crazy amount of knock. my a/f is 10.5. when i had 20 degrees of timing on 20 lbs. of boost there was a ticking noise coming from my motor? i have recently done a compression test and all cylinders were with in 20%.
what could be wrong i had my friend who tunes my car save the data so i can upload it if someone want to try and help me whats wrong
Old Sep 2, 2008 | 01:57 PM
Old Sep 2, 2008 | 02:02 PM
rrutter81's Avatar
logs will help
Old Sep 2, 2008 | 02:10 PM
matego's Avatar
Are you 100% sure you have good gas? My wife put 89 in the car the other day and when I logged it the timing would go to 14-15 and start knocking around 3500. Small town gas stations are horrible up here for "accidentally" putting the wrong octane in the tank.
Old Sep 2, 2008 | 02:22 PM
Area47's Avatar
Rent me! per hour
within 20%? the RnR limit is 13% on the high side.
i personally think the damage is done.
Old Sep 2, 2008 | 02:34 PM
rrutter81's Avatar
er yea, what are the cylinder readings for each? Also did any of them go "to" within 20% of a cylinder and then level off or were off more and went to 20%?
will help a great deal
Old Sep 2, 2008 | 09:08 PM
compression test 165 for 3 of them the 4th was 170
yea i put 93 in at a chervon
can u send me r email i dont know how to post this file
Last edited by heyitsmikey1987; Sep 2, 2008 at 09:08 PM. Reason: Automerged Doublepost
Old Sep 3, 2008 | 09:13 PM
Old Sep 3, 2008 | 09:44 PM
Area47's Avatar
Rent me! per hour
iat adders. afr adders. ect adders.
check them.
Old Sep 5, 2008 | 09:01 AM
myguy who tunes said thats not the cause idk he saying there either something wrong with a valve or lifter im so **** right now cause this car is slow as hell im about to sell it for a SRT4
Old Sep 5, 2008 | 03:32 PM
C0baltWithM0ds's Avatar
thats what im doing these cars were never made for big horsepower there slow im close to getting a white srt 4 just waitin to see if this kid wnats my car or not. if i wasnt stupid a year ago i never would have bought this slow pos idk what i was thinking seriously
Old Sep 5, 2008 | 06:28 PM
brett5's Avatar
what pulley size do you have and what size injectors
Old Sep 5, 2008 | 06:47 PM
Area47's Avatar
Rent me! per hour
tell your special "tune" guy to look at the adder tables and do simple math.
Old Sep 5, 2008 | 06:50 PM
mods:
2.7 zzp pulley
60lbs injectors
k&n typhoon cia
hp tuner tune
16in saab 9-3 10 spoke rims
hurst short throw shifter
aem wideband
aero interceptor
ais alky injection
4.2 liter tb w/rebel adaptor
cobra h/e
derale eletric fan attached to h/e
dual-pass setup
wingless trunk
ported blower
drilled and sloted rotors
cobalt -addiction 3inch downpipe
magnaflow muffler 3inch inlet and 4 inch out
nexuim n3000 225/45/16
bigdeertz
Nov 17, 2016 09:41 AM
Cobalt08LS
Jun 19, 2016 07:29 PM
brandon04
Oct 21, 2015 07:04 AM
satisfied
Oct 19, 2015 12:35 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
