Problem with torque damper
I just recently installed my Ingalls and I'm having a few problems. For some reason I cant get the nuts to adjust properly. They are at about 14mm-15mm right now and I need them to be at the recommended 12. When I try to turn them, the whole damper turns, not the nuts. Also, I drove it only once since putting those on and the car has a weird vibration when I start from a dead stop. Anyone else have these issues or know what could be going on?
Yes it will make vibrations in the cab. The way you adjust it is by loosen the lock nut and turn the bottom nut of the two counter clock wise and then turn the top nut clock wise to shrink it down to 12mm then take both of them at the same time and turn it clock wise back into the dampner and lock the lock nut down and your done. If this is too confusing theres a How to for this in the how to section.
DANRICKARD
Oct 1, 2015 12:08 AM
