Problems Boost TVS!! 13-14 boost
The problem is i am only boosting 13-14 pounds of boost with the stock TVS pulley, I dont know what happen, i have check in the site but havent found nothing, I get the carb cleaner to check leaks but nothing,my mas air sensor is good and clean, and i clean the throttle and air intake, the car gives me the PO300.
Maybe the intake manifold gasket under the TVS? Suggestions?
Thanks you for your cooperation
Search Boost Bypass mod and try that. It's an ancient mod from 2004-2005 and is almost useless now except for diagnosing bypass issues.
If it works you are having bypass issues and need to get that resolved.
Don't run the boost bypass mod long, It's only a tool to help diagnose issues and not in anyway a viable fix or really safe.
If your bypass isn't working correctly you will only create minimal boost, the mod will temporarilly disable the bypass and allow full boost all the time.
Report back, and talk to Area about why you are misfiring!
ok Its out now going to test
ok i test it and the car boost 17 max but at 6k the car starts to lean or like holding making a noise and i stop. maybe should i gap the spark plugs a little more but it throw higher boost what should i do now?
i am going to gap it a little less like .28
And if i have 20 boost with this, what should i replace, what part?
