Problems Boost TVS!! 13-14 boost
Old Sep 27, 2009 | 04:28 PM
efrommel's Avatar
Unhappy Problems Boost TVS!! 13-14 boost
The problem is i am only boosting 13-14 pounds of boost with the stock TVS pulley, I dont know what happen, i have check in the site but havent found nothing, I get the carb cleaner to check leaks but nothing,my mas air sensor is good and clean, and i clean the throttle and air intake, the car gives me the PO300.
Maybe the intake manifold gasket under the TVS? Suggestions?
Thanks you for your cooperation
Old Sep 27, 2009 | 04:29 PM
Jared B's Avatar
might be the boost bypass unplugg it
Old Sep 27, 2009 | 04:30 PM
Sizzle06's Avatar
The p0300 is for a misfire,who tuned you?
Old Sep 27, 2009 | 04:36 PM
efrommel's Avatar
Area is curently tunning me
"UNPLUGG IT " should i unplugg ? which one is that?
Old Sep 27, 2009 | 04:37 PM
drew1991sf's Avatar
are u actually feeling the misfire? i was gettin misfire codes becuz of my 60's and how they idle.
im thinking u dont have a line connected or not tighten down all the way
Old Sep 27, 2009 | 04:39 PM
efrommel's Avatar
line from an injector?
leviticus88's Avatar
Search Boost Bypass mod and try that. It's an ancient mod from 2004-2005 and is almost useless now except for diagnosing bypass issues.
If it works you are having bypass issues and need to get that resolved.
Don't run the boost bypass mod long, It's only a tool to help diagnose issues and not in anyway a viable fix or really safe.
If your bypass isn't working correctly you will only create minimal boost, the mod will temporarilly disable the bypass and allow full boost all the time.
Report back, and talk to Area about why you are misfiring!
Old Sep 27, 2009 | 04:40 PM
efrommel's Avatar
because when i install the TVS i had go to 18-20 boost, is just like a few days ago that i notice the change
Old Sep 27, 2009 | 04:42 PM
Jared B's Avatar
when i was being tuned i was hittin 15, i unplugged i was hittin 20
Sounds like bypass failure or maybe belt slip.
Old Sep 27, 2009 | 04:46 PM
efrommel's Avatar
is the bypass cover it by the harrop waranty?
Old Sep 27, 2009 | 04:47 PM
Jared B's Avatar
its not going effect the waranty
Old Sep 27, 2009 | 04:52 PM
efrommel's Avatar
going now to test the bypass mod, i just unpluged and ready?, what should i see
Old Sep 27, 2009 | 04:53 PM
Jared B's Avatar
18-20 psi
Old Sep 27, 2009 | 04:54 PM
efrommel's Avatar
Wow that hose its hard to take off!!!!
Old Sep 27, 2009 | 04:55 PM
Hell ya! lol
Anything change?
Old Sep 27, 2009 | 05:00 PM
efrommel's Avatar
i am trying to take it off!!! lol
Old Sep 27, 2009 | 05:01 PM
Jared B's Avatar
it shouldnt be that hard
Old Sep 27, 2009 | 05:16 PM
Jared B's Avatar
just unplugg it from the bypass it shouldnt be glued
Old Sep 27, 2009 | 05:41 PM
efrommel's Avatar
ok Its out now going to test
ok i test it and the car boost 17 max but at 6k the car starts to lean or like holding making a noise and i stop. maybe should i gap the spark plugs a little more but it throw higher boost what should i do now?
Old Sep 27, 2009 | 05:46 PM
Jared B's Avatar
gap @ 32 bring up to 7k
Old Sep 27, 2009 | 05:47 PM
efrommel's Avatar
its already gap at 32
Old Sep 27, 2009 | 05:54 PM
Jared B's Avatar
i think you will see more boost if you bring it to 7k
Old Sep 27, 2009 | 06:00 PM
efrommel's Avatar
i am going to gap it a little less like .28
And if i have 20 boost with this, what should i replace, what part?
Old Sep 27, 2009 | 06:06 PM
Jared B's Avatar
since you have that 3" exhaust you wont see 20 until 6500 or higher
