Project 35R Redline
Old Jul 21, 2007 | 06:07 PM
Ryze's Avatar
megasquirt is wonderful.. I am very familar with it. I used it on my turbo 2200 cavalier, and then again on a high compression 2.4 twin cam z24 with nitrous. i was very pleased with it for daily driving and how easy it really is. the MS website throws alot of info at you, but its good to learn every last thing on it.
Old Jul 21, 2007 | 06:15 PM
Mikey851's Avatar
With Megasquirt do you have to run some of their sensors or is it compatible with the stock sensors (ie crank postion).
Old Jul 21, 2007 | 06:19 PM
Witt's Avatar
It can be programmed to work with nearly anything.....except drive by wire.
Old Jul 21, 2007 | 06:24 PM
Ryze's Avatar
and variable valve timign.. but we dont have to worry about that.
honestly i don't know what type of ign sig is run on the LSJ, i've "heard" that its like a 52 trigger wheel? but i'm not sure. Most people convert to EDIS, because its easily modified and can work with almost anything. I however used the only style GM DIS, because ms is able to use that.
now that i think about it, the trigger wheel might be the only problem with this, unless you swap to EDIS
Old Jul 21, 2007 | 06:34 PM
Witt's Avatar
CKP is 60-2 with a variable reluctance sensor I think. I think the LE5 uses the same but with a hall effect sensor.
Way better off to just run a fake 3 bar tune with the stock PCM in speed density since he would have to keep the stock PCM connected anyway.
Old Jul 21, 2007 | 06:36 PM
aja342's Avatar
screw twincharging...fab an adapter plate over the stock intercooler with a LS1 t-body and MAF.....I know I'm dreaming.....I'll shut up now
Old Jul 21, 2007 | 06:37 PM
Ryze's Avatar
lol yeah probably, with the ability to use HPT i'd consider that over MS, just because of the hassle thats going to be with the ign set-up.
although you could use Megasquirt as an injector driver or secondary injector controll and HPT for ign timing
or just bit the bullet and get an a different standalone that will work with less work lol if there is such thing
Old Jul 21, 2007 | 06:48 PM
Area47's Avatar
Rent me! per hour
right on.
at least someone listened when i said 35r
i vote for hydra ems
Old Jul 21, 2007 | 06:51 PM
Witt's Avatar
Originally Posted by Area47
right on.
djt81185 is talking with Hydra people and they are interested in developing a plug and play application for us.
Old Jul 22, 2007 | 01:30 PM
Area47's Avatar
Rent me! per hour
ohhhh, that makes me happy in the pants
Old Jul 22, 2007 | 01:35 PM
  #36
AWDstylez's Avatar
We're also considering an SAFC.
And Syp, I'd LOVE to hear your amazing technical knowledge on what makes tuning a twincharged car sooo much more complicated. Air is air buddy, it doesn't matter how it gets in there.
Old Jul 22, 2007 | 02:54 PM
  #37
Ryze's Avatar
lol, well if your considering a safc, i take it you don't want this to last long j/k
he's probably talking about the torque curve of a twin charge system, as it is quite different than a s/c set-up or turbo set-up. but you should be able to manage that.
Old Jul 22, 2007 | 04:43 PM
  #38
AWDstylez's Avatar
That's what all the people that have no experience with them say. You'd be amazed with how well they work, especially for a daily driver.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
z28addiction
Sep 28, 2015 12:03 AM
Rduncanss06
Sep 27, 2015 11:17 PM
