View Poll Results: PSI FI or GM Performance Upgrade?
PSI FI Kit.
3.57%
GM Performance Upgrade.
85
75.89%
Undecided.
18
16.07%
Already Have PSI FI Kit.
4.46%
Voters: 112. You may not vote on this poll
PSI FI or GM Upgrades
Old Nov 3, 2005 | 02:44 PM
undrgrndcobalt's Avatar
Would you rather go with the PSI FI kit or the GM Performance Upgrades next year? Just Curious.
Old Nov 3, 2005 | 02:49 PM
silverSS's Avatar
Undecided for now, im liking the psi fi more and more every day b/c GM is holding back on us, and we dont have prices on GM yet
Old Nov 3, 2005 | 02:50 PM
R33P3R007's Avatar
360 L337 User
Agreed ^^^^^
Old Nov 3, 2005 | 02:51 PM
R33P3R007's Avatar
360 L337 User
or an actual release date
Old Nov 3, 2005 | 02:53 PM
Co27SSKid's Avatar
WHAT ABOUT THE TWIN CHARGER KIT????!!!!! ooo rrrriiiggghhhtttt giggidy giggidy giggidy
Old Nov 3, 2005 | 03:12 PM
silverSS's Avatar
only reason i wouldnt do that is relaibility reasons, i dont need that fast of a car....
Old Nov 3, 2005 | 03:15 PM
zinner's Avatar
Moderator Alumni
I am having someone check for me but so far the part isn't an 'active part' yet so there is no pricing, they are checking a couple other places , doesn't look like they have a price yet.
Old Nov 3, 2005 | 03:18 PM
Does the PSI FI kit void warranty?
Old Nov 3, 2005 | 03:25 PM
2006ArrivalBlueSS's Avatar
I think it would have to. It would be a pretty tough arguement with GM explaining that you spliced into their factory wiring harness to overide their factory settings and you can't figure out why that piston went through the hood when you revved at 7000 RPM ('cause you overode the factory rev limiter)
Old Nov 3, 2005 | 03:27 PM
Alex47's Avatar
yes
but it is worth it
Great Stuff
Old Nov 3, 2005 | 03:31 PM
R33P3R007's Avatar
360 L337 User
Old Nov 3, 2005 | 06:03 PM
SloBaltSS's Avatar
Wait a tic... the psifi kit changes the rev limiter too!!?!? This is the first I have heard of this... if thats the case f*ck waiting for the GM stages...
Old Nov 3, 2005 | 06:12 PM
OniMirage's Avatar
the stage one reflash aparently is suposed to change the limiter to 7k rpm
Old Nov 3, 2005 | 06:14 PM
dimeo09's Avatar
damn 7k we'll be hitting 13.9's
Old Nov 3, 2005 | 07:09 PM
WopOnTour's Avatar
The PSIFI kit does NOT override the factory rev limiter!
BUT I predict...
Combining the GM Stage 1 with the 2.80" (71.1mm) PSIFI pully and a "retuned" PSIFI Powerpaq will become the dominant combination for the LSJ. Just stamp 77.9mm on the PSIFI pulley and hide the Powerpaq for "full stealth" mode.
To any tech it will look like Stage 2
This would still only spin the M62 to 15000 RPM which is still well below the 16,000 maximum "peak" RPM the M62 is rated for (14,000 rpm is it's CONTINUOUS maximum speed)
WopOnTour
Old Nov 3, 2005 | 07:26 PM
JoeyCobalt's Avatar
Stock internals can take up to 7500rpm, to spin more you just need to replace to valve springs not even the seats or keepers.
Old Nov 3, 2005 | 10:19 PM
phxSS's Avatar
Actually a GM engineer that was interviewed on Street Tuner Challenge, said the bottom end can handle 8000 rpm all day, but the valve train can't. Supposedly, that's all you need to change to get to that mark.
Old Nov 3, 2005 | 10:24 PM
alleycat58's Avatar
For me it's going to depend on how much GM wants for a pulley...
Old Nov 3, 2005 | 11:58 PM
Maverick's Avatar
this all hinges on what gm will charge for the stage upgrades.
Old Nov 4, 2005 | 12:14 AM
Mercury's Avatar
That is awesomeness! I would love to rev past 6500!.
And wow the polls are a complete shutout. GM upgrades owns!
Old Nov 4, 2005 | 01:20 AM
BlAckOnBLaCK's Avatar
I would looooove GM prices.
Old Nov 4, 2005 | 01:38 AM
GotBoost?'s Avatar
Same here depends on the price. If they are anyhting like the mopar stage upgrades for the str-4, then i will buy one for sure. But every chevy owner knows that chevy parts for so damn expensive.
Old Nov 4, 2005 | 11:03 AM
SCdyne's Avatar
Correct and to add to that - the 8000 rpm is only reasonably possible with correct Balance & Blue print on the engine including larger tolerance for the crank bearings.
We have found that you want to open up the clearance on the bearings and run good - clean synthetic oil if you plan to spend any time in the 8000 range.
I think the poll needs a "both" option because a Stage 2 package and a tuned PSI FI set-up would just be amazing.
Old Nov 4, 2005 | 11:44 AM
tsmock's Avatar
I agree. That would be awesome.
