pulley
depends on how much money you have to throw around. You could go slightly smaller 3" with injectors, belt, tune and be around $300, or a little smaller 2.8" 60# injectors, belt, plugs tune, h/e etc and be $500-$600. If this is your first mod, go for cold air intake or exhaust set up.
It's better to go with a whole stage kit, so you get everything you need. But if you pulley down, that means more air coming in, so you need more fuel to match
but with an intake that also means your pulling in more air so this will obviously change the afr's. im a newb at this so please be patient with me as this is only a question. since your pulling in more air with the intake, do you automaticly need a tune or can you run an intake safely?
patooyee
Oct 1, 2015 01:07 PM
