pulley question
Old Mar 19, 2008 | 09:12 PM
06_cobalt_SS's Avatar
pulley question
i have stage 2 but what is the pulley size on it. i see alot of people have like 2.8 or 2.85 or whatever. if the stage 2 pulley is bigger than that what is the best size pulley you can get without blowin your engine up. and where can you get this pulley. another thing if i put the smaller more power adding pulley on my car what happens....nothin because of the stage 2 reflash will only let a certain amount of boost and power.....or i get more boost and more power....just some questions any help would be greatly appericiated.....dont forget to add where i can buy a pulley
Old Mar 19, 2008 | 09:19 PM
srowler9's Avatar
Stage 2 pully is around 3 inches.
You will not want to go smaller than a 2.9 on a stage 2 tune.
A smaller pulley will allow you to gain more psi from the supercharger. It spins the charger faster, therefore; pushing more air. The thing that will blow the motor, is putting the injectors over their limits. when you use a smaller pulley, you are pushing more air in the motor. The injectors try to keep up with the A/F ratio that is dialed in from the tune. If they can't keep up then you have major problems. Burning out pistons and blowing your motor.
you can get the pullies from a lot of different sites. A member on here (supporting vender) his name is Nate. He customs a lot of pulley sizes. I can't remember his vender name, but someone will chime in
Old Mar 19, 2008 | 09:26 PM
AjSS's Avatar
^smoothflowpulleys.com
Old Mar 20, 2008 | 12:34 AM
nherbst454's Avatar
Here I am, www.smoothflowpulleys.com/Stage2.html
Nate
Old Mar 20, 2008 | 12:36 AM
EceSSiveMod's Avatar
its sumthin like 3.06....jut go 2.9 if ur wanting to go smaller
Old Mar 20, 2008 | 01:13 AM
rockkrawler628's Avatar
Originally Posted by nherbst454
lol nate your everywhere where the word pulley is in the title
Old Mar 20, 2008 | 01:15 AM
lsjwannabe's Avatar
go 2.9 if you want lots of people run it, i feel safer with a custom tune though.
Old Mar 20, 2008 | 01:18 AM
kwest's Avatar
hey if i was use i would make sure you can get your stage 2 pulley off before you buy a pulley. I bought Nates 2.85in polished pulley probably 2 months ago (outstanding product btw) and when i went to install it my pulley bolts were waaaayyy over tight. i literally snapped the bolt adapter that comes with the stage 2 kit for the blue bolts in 3 pieces..so i then tried a impact with an extension, still wouldnt come off. so i called my dealer and bitched and bitched and im actually going up there tomorrow and they are completely taking off my blower and drilling out the bolts and putting on my 2.85in pulley, which i will definetly make sure they only do 15lb/ft of torque this time!!!!
Old Mar 20, 2008 | 01:19 AM
lsjwannabe's Avatar
they used locktite
Old Mar 20, 2008 | 01:35 AM
9cobra4's Avatar
Kind of weird to make my first post in here but anyway, i dont mean to highjack your thread but you all are saying you can run a 2.9 with the rest of the stage 2 stuff safely? or would it be in need of a custom dyno tune?
Old Mar 20, 2008 | 01:38 AM
BLAZIN07SS's Avatar
I'm too JDM for you
yes you can run a 2.9 on the stage 2 tune perfectly fine. dont go smaller than that though because Injector Duty Cycles will be through the roof
Old Mar 20, 2008 | 01:41 AM
9cobra4's Avatar
Thanks for the quick reply, i dont have a cobalt yet, but probably will within a couple weeks, if i can get rid of my gtp.
Old Mar 20, 2008 | 01:44 AM
lsjwannabe's Avatar
you should see stage 2 let alone a 2.9 but if it works whatever
Old Mar 20, 2008 | 01:56 AM
chood711's Avatar
just get on ebay and get nates 2.9, thats what i did and loved it. you can tell a difference.
Old Mar 20, 2008 | 02:14 AM
AjSS's Avatar
^ You dont have to get on ebay, just order it from his site, its www.smoothflowpulleys.com
He has great service and a great product.
Old Mar 20, 2008 | 02:16 AM
G85 SS's Avatar
2.9 works great for me on stage 2 tune. have had no problems or anything. Also, I hope you have the NGK 1 step colder plugs. if not you might want to get those as well.
Old Mar 20, 2008 | 02:54 AM
BLAZIN07SS's Avatar
I'm too JDM for you
its not that bad...got my car logged not too long ago. until 5800rpm i was at 11.7afr and then it jumped down to 10.2 cause stage2 runs retardedly rich. at redline my IDC's were at 94%. close to maxing them out, but not quite yet. lol
Old Mar 24, 2008 | 08:57 AM
Texas SS's Avatar
id go 2.9 for stage 2 tune
Old Mar 24, 2008 | 09:14 AM
fiftyandsoco's Avatar
i am about to run a 2.9 pulley. from all the research i've been doing, you will need at least 42# injectors, 1 step colder plugs, and a CAI (or other means of increased cold air flow) to avoid the risk of blowing your motor due to strain. PCM tune is also recommended. any mid-east cobalts, check out Tom's tuning, it's great! His name on here = wickedSS2005
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
