pulley question
Old Dec 9, 2008 | 07:08 PM
EXsoccer1921's Avatar
pulley question
alright. will a 3.15" pulley be fine on the stock injectors and tune?? i'm thinking about getting in on the billet flow sale and spending the $75 for a pulley and hub but they don't make a stock size.
Old Dec 9, 2008 | 07:24 PM
nherbst454's Avatar
I've currently got a group buy going for a pulley system for 81.00 w/free shipping and you can have ANY size you want.
Here's the thread...
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/smoothflow-pulleys-group-buy-143485/
Nate
Old Dec 9, 2008 | 08:42 PM
Old Dec 9, 2008 | 08:43 PM
revolution607@yahoo.'s Avatar
i'd say you would be fine running it but thats just my opinion.
Old Dec 9, 2008 | 09:18 PM
Black Screamer's Avatar
you should be pushin like 15 PSI. Anymore and its gonna be bad news
Old Dec 9, 2008 | 09:21 PM
JimzSS's Avatar
you will be ok. nate makes a good set up.
Bika's Avatar
Fail Less.
alot of people have gotten away with as small as 3.0 on stock injectors and stock tune, but I wouldnt recommend it. You should get 42#s and a tune.
Old Dec 9, 2008 | 09:24 PM
JimzSS's Avatar
did the 3" on stock tune for a bit. pulled good. 13.80@102
but then I went stage 1 and completed the transition.
no damage done, some will say I was lucky.
Bika, you have hptuners?
Old Dec 9, 2008 | 09:34 PM
Bika's Avatar
Fail Less.
Yes I do. Need some work done?
Old Dec 9, 2008 | 09:47 PM
okay so i should be just fine on a 3.15 but its not really recomended?
Old Dec 9, 2008 | 09:49 PM
BLAZIN07SS's Avatar
I'm too JDM for you
let me put it to you this way. "stonny" down i south florida has a stage 2 pulley on stock injectors and tune and he has 154% Injector duty cycle. it runs hard as **** for such little work done to it though
Old Dec 9, 2008 | 11:31 PM
well thats a 3", not a 3.15". it doesn't seem like a lot for buts halfway between stock and stage2. maybe i'll just get the 3.3" pulley and hub for now and just wait till i get some more money and get the pulley injectors and tune
Old Dec 10, 2008 | 09:25 AM
stonny9's Avatar
I also have intake, haeder, and downpipe
Old Dec 10, 2008 | 09:27 AM
tim0shel's Avatar
Free bump for Nates pulleys. They look nice.
Old Dec 10, 2008 | 12:24 PM
rnjmur's Avatar
On a stock tune the car will bleed boost to 12.5 PSI I believe. With that in mind, you should be fine with a 3.15" pulley. The injectors may run high IDC before boost bleeds off but you will reach higher boost numbers sooner in the RPM band giving you more mid range HP and TQ.
Old Dec 10, 2008 | 12:38 PM
ShortStack's Avatar
Yes, because you dont reach 12.5 automatically, it takes a couple thousand rpms..
So instead of being at like 7 at 4000, with a smaller pulley youll be closer to 9 or so, but still only reach the 12.5 mark.
Old Dec 10, 2008 | 08:06 PM
stonny9's Avatar
just pull the boost bypass vacume hose and plug it. takes all of 2 mins. I pulgged mine 2 days after gettion the smaller pulley because I heard ad say it bleeding boost on the guage. It bleed to 10 psi
Old Dec 10, 2008 | 08:16 PM
Perfect.disguise's Avatar
Not with a 3.15. I was pushing 15 with a 2.9.
To be honest the stock stock setup and the Stage 2 setup is working the injectors pretty hard. A 3.15 with stock tune will see pretty high IDC.
GM Stage 2 is 3.06
Old Dec 11, 2008 | 12:02 PM
rnjmur's Avatar
Not only will this kill your gas mileage, but pulling the boost bypass really isn't a great idea. Having air running through the SC at all times just creates more heat and wear on the SC. Also, on stock injectors you really don't want to be hitting 14~14.5 PSI or you will be running some insane IDCs.
Old Mar 21, 2009 | 11:04 PM
stonny9's Avatar
kinda old post but just saw it again. I have the boost bypass on stock tune with stg 2 pulley, i/h/dp and my gas mileage hasnt dropped one bit.
Yesterday I finally got the full stg 2 setup. next is a 2.8 and a minor tune.
Old Mar 22, 2009 | 02:17 AM
wow this is pretty old haha.
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
