pulley question
Old Feb 19, 2009 | 02:19 PM
chilisickle's Avatar
pulley question
what size pulleys; on a stock supercharger, will put me at 15 psi or just above? and, will it require 60+# injectors and a tune to make sure it doesnt blow up.
Old Feb 19, 2009 | 02:20 PM
chris88z24's Avatar
my setup./
tdipowered's Avatar
3.0 and 42s
Old Feb 19, 2009 | 02:23 PM
06SS ALL DAY's Avatar
3.1 pulley and no injectors needed bigger injectors are needed for 3.0-2.8 (42 injectors) after that than 2.7-2.5 get 60's i'm running a 3.1 and getting 15 3.0" pulley should get you 15.5 or 16 if not something is wrong with your tune
Old Feb 19, 2009 | 02:28 PM
rnjmur's Avatar
Hitting a specific PSI will depend on where you are at from sea level. In NJ you should be fairly close to sea level so a 3.1" pulley would get you to 15 PSI. If you drop the pulley size you need to go to 42# injectors. Anything smaller than a 2.9" pulley and you should have 60# injectors.
Old Feb 19, 2009 | 04:09 PM
chris88z24's Avatar
You couldn't be more wrong.
Old Feb 19, 2009 | 04:17 PM
ShortStack's Avatar
I would change your injectors if your changing your pulley at all..
Old Feb 19, 2009 | 05:57 PM
Thanks for the info everyone!
Short stack. Can I get a sound clip of your exhaust? Pm me, I'll explain.
Old Feb 19, 2009 | 06:50 PM
mattcossel29's Avatar
depends on the densitiy of the air.. I have seen over 16 psi out of the stock pulley.. but it was around 25 degrees and i am in iowa
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
