pulley size, with full bolt on's/meth
ok guys, as some of you kno, i recently bought a crap load of parts for my balt, im at full bolt ons. here they are.
zzp 1.0 pcm
injen CAI
GMPP cat back
bad mab header
phenolic intake spacer
zzp dual pass plate
zzp s3 heat exchanger
zzp 3.0" pulley
gm stage 2 belt
zzp TB spacer
option B tank/bracket
NGK bkr7e v power plugs/ 1 step colder
seimens #50 injectors
zzp top motor mount
zzp front/rear tranny mounts
AIS stage 1 meth injection system
eibach sportlines
my question is, i know i can run a smaller pulley, my s/c is cool to the touch after a few pulls and i love it. would i be able to safely drop down to a 2.6? or just drop to a 2.8? my next upgrade in a gm upgraded clutch btw.
zzp 1.0 pcm
injen CAI
GMPP cat back
bad mab header
zzp dual pass plate
zzp 3.0" pulley
gm stage 2 belt
zzp TB spacer
zzp top motor mount
eibach sportlines
Honestly, get s custom tune and go to a 2.9 which will prob be the most u can go.... Safeltly without getting high idcs. I ran the 50s at a 11.2 afr and idcs were 96% on a 2.8 and also a 2.9 with idcs of 93%
dropping the cradle is a pain to start with. I'm doing a complete overhaul of my car and to get the trans out and down was pretty bad. Bolt ons are cake compared to that work
zzp said theres no need for anything larger than 50's on a m62, unless your running e85. i might just got to a 2.8 then and try that. its winter time, im just trying some things out when the roads get nice once and a while and in spring ill have a custom tune.
Lol....... I swear sometimes.... Just because zzp says somthing doesn't mean its fact.... 50s can hold a m62 over but there's a lot of things that come into play with your tune .. elevation, timing, afr wot, ect if your tuning 12.3-11.9 ages I'm sure you can do it on a m62 but your asking for issues. The heaton makes heat so therefore a leaner afr plays a big part is the kabooms in the lsj. So 60s are a whole lot better because not only do you have room with the 60s but your not maxxing nor are you getting static injection. Having 60s give you more leeway.....
This.
I'm running a 2.7 Right now, on 60's.
My supporting mods are:
Custom Tune
Option B
Dual Pass End Plate
Stage 3 ZZP Front mount H/E
NGK Sparks
2.7" Pulley
60# Injectors
& I'm pushing 285 ish
Custom Tune
Option B
Dual Pass End Plate
NGK Sparks
2.7" Pulley
60# Injectors
dyno sheet? I got all that and a 2.8 but doubt im pushing that much power. still need to dyno
patooyee
Oct 1, 2015 01:07 PM
