Pulley swap
Old Dec 1, 2007 | 03:51 PM
SmOKe JeNsOn's Avatar
Pulley swap
So i was looking up the how to and there were only 2 that i could find but do you really have to take the supercharger completley out to install these? I am gonna have one of the techs at work help me he has a puller. Or is there an easier way then what the write ups say?
Old Dec 1, 2007 | 04:00 PM
SlowBalt_06's Avatar
do u have the stock press on pulley..if you do you will need to remove the supercharger its not that hard though..4 bolts and 2 sensors and the belt i think thats it off the top of my head...if not just push the idler pulley down to remove the belt and take off the 4 bolts and put the pulley on and your good...
Old Dec 1, 2007 | 04:05 PM
yea its stock, putting on a 3.2
Old Dec 3, 2007 | 11:41 AM
chevysalesman614's Avatar
then yes, you do have to take the supercharger off. its actually alot easier than you think it would be. when i had my cobalt i took off my blower in >10minutes. then once i had done it already, i cut my time down to >5minutes. i assure you, its easy. get some tape, and number every connection that you remove, then it will all go back together smoothly.
Old Dec 3, 2007 | 12:35 PM
devilsown's Avatar
SmOKe JeNsOn I am in okc i can help you if you need it. I also have a pulley puller somewhere in my garage thats collect dust since i yanked my pulley off.
Old Dec 3, 2007 | 02:33 PM
Thanks but I a guy at work has one its just him getting time to help me with it so i was gonna go ahead and take the supercharger out and just take it into the shop so he could take it off and put the new one on
Old Dec 3, 2007 | 02:48 PM
fsickness's Avatar
You know I had to take the damn thing off to change out my STG 2 Pulley. GM used so much LOCKTITE that I bent a nubby craftsman screwdriver. I ended up heating the bolts up with a torch (after I dremeled a straight line across them to fit a straight blade screwdriver) and used another nubby to get them off. Thank god I bought more bolts from nate to replace the existing ones. Moral of the story...Never used red locktite all the way up and down the bolt...lol
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
