pulling timing
Old Feb 2, 2012 | 10:23 PM
advise's Avatar
pulling timing
had my car tuned last year by byt having a little problem with it knocking
at 6k it starts to knock about 6* and goes to about 12* right when i let off at 6200rpms
air/fuel seems good at a 11.8ish
had the car tuned in 60* weather
its 38 out right now
also my muffler is f'ed right now baffles could be restricting flow
meth is good cleaned the nozzle filter yesterday, checked the pressure switch which is set to come on at 10 psi
any ideas
Old Feb 2, 2012 | 10:31 PM
drumrush's Avatar
Mine has KR too but only 3-4*
Old Feb 2, 2012 | 10:32 PM
ULWizSS's Avatar
Check your IC pump yet. What are your iat2 temps getting too?
advise's Avatar
ya mine started ramping up kr
maybe im pulling a high maf frequency
Old Feb 2, 2012 | 10:34 PM
advise's Avatar
pumps done(have new one but too cold to put it in)
iat2 hits like 110*
but i though it will on pull timing after like 140* iat2
Old Feb 2, 2012 | 10:36 PM
Bika's Avatar
Fail Less.
If you're getting 12* KR your engine isn't gonna live too long if you keep pushing it.
Exhaust restriction could be the cause, or bad gas. If the meth is spraying I doubt it's because of high IAT2...
Old Feb 2, 2012 | 10:39 PM
advise's Avatar
nah this is my second tank that its doing this on
once i see it hit anything over 6* i back out
but by time i back out it spikes 12*
Old Feb 2, 2012 | 10:41 PM
advise's Avatar
though maybe i miss mixed my last 2 gallons of meth and water but this would cause a lean afr
did also adjust my pressure switch for 6psi to 10 psi(so i would spray when getting on a highway ect)
spark blow out?
Old Feb 2, 2012 | 11:52 PM
mrbelvedere's Avatar
get your exhaust fixed if it is restricting it it will cause it to knock
Old Feb 3, 2012 | 01:03 AM
383_Stroker's Avatar
and quit beating on it until you do...
Old Feb 3, 2012 | 01:48 AM
advise's Avatar
yup clogged exhaust
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
n20saturn
Sep 21, 2015 01:50 AM
The Rookie24
Sep 20, 2015 04:33 PM
OrangeK
Sep 20, 2015 03:02 AM
