Putting together motor... need help!
ok so i am putting it all back together tonight. i have the diamond pistons 9.5:1 comp, with total seal rings... i got the top ring and the second ring in... now i am to the oil ring... or the last ring... it is actually a set of 3 rings... a goldish colored wavey ring that has two really thin little rings that go on either side of it...
the problem: when i try to put the middle gold wavey ring in its kinda big. i tried to over lap and lock it into the next ridge but you cant... so do i trim it back?
any help would be great!!!
thanks in advance
thanks in advance
well, I don't know if the specs for the aftermarket rings are different, but here are factory
first ring. .15 - .30 mm
second ring .4 - .6 mm
oil control ring/rails .25 -.76 mm
and yes, push the rings down into the bore of the cylinder about an inch w/ the piston. make sure the ring is level and measure the gap with a feeler gauge
well you will always get a lil blow by its just a matter of how much
so i took the bore and converted it to inches...about 3.385" and multiplied by .0055... which gave me .018" thats what the top ring gap should be. multiplying by .0055 is what is recamended by total seal for blown gas motor (blown as in forced).
the second ring is to multiplied by .0035 which gives you .011" gap
the oil rings i was not sure about i now have answers to.
the gold wavy ring is supposed to be slightly over sized but it crunches down... the redges can compress to fit in the cylinder and then it pushes out to seal better...
and the small thing rings that go ontop and bellow it are supposed to be gapped at .015"
hmmm ok i am stuck again
do the rods have to go in, in the same order? and are they directional?
Last edited by red_line_cobalt; Apr 10, 2008 at 02:49 PM. Reason: Automerged Doublepost
Is this your first time building an engine?
EDIT: Figured I'd be useful. I recommend buying that ecotec build book that's around here somewhere. I'd hate for you to blow up a brand new motor.
on my own yes... first time doing one period no. i have worked on a few different motors... but nothing as new as this... and i have never done one by my self... so i want to follow up on all the things that i keep second guessing.
with removing the head u will have to do the propor things to take it off. it not just on bolt and lift.. u will have a lot to remove and un hook
I was planning on doing my build the way you are, without removing the block. But if I want to replace the main (crank) bearings, can I remove the crank without removing the block. My next unit ought to have an engine lift, I am just curious.
well, I'm sure you could if you really really wanted to......however, the flywheel is bolted to the crank. So you have to remove the transmission and remove the flywheel to get the crank out of the block.
yep youd have to unbolt anything thats attached to the girdle...thats whats holding the crank in...as for putting the rods god just make sure you dont nick the crank with them....and make sure you have the same rods/bolts/caps/ that came off of that specific cylinder...if all is new which i think i read it wont matter...just roll the crank and put them in....i forget but i think you should be able to do two at a time without having to roll the crank...i think thats how i did it on an older 4 cylinder in shop class
yea i know...i just meant in addition to whats attached to the crank....that girdle is really all thats holding it in
yes, however he was asking if he could remove the crank with the motor still in the car. You said he could......Which, wouldn't be really the best way to do things......since he would have to removed the transmission so he wouldn't have support on the drivers side of the motor.....he couldn't jack the motor up and hold it from the bottom since the oil pan will be off. Also he woudln't be able to use an engine support or hoist since the head and everything will be off.....it might not be easy to hook it up. If you want to replace the crank/main bearings...pull motor.
ok thanks guys. that was a dumb question, If I would have thought a little harder about it I would have realized a second later "******* you have to unbolt the flywheel" which means it would clearly be easier to pull the motor. thanks
