Putting together motor... need help!
Old Apr 10, 2008 | 09:32 PM
Shanman's Avatar
rod condoms protects ur crank. make sure u position major and minor thrust in the right ares and 1st ring should be inbetween thrust and rod hole and second should be 180degrees and oil ring should be 90 degrees off those two
Old Apr 11, 2008 | 03:13 AM
jperris's Avatar
Originally Posted by red_line_cobalt
... i got the top ring and the second ring in... now i am to the oil ring... or the last ring... it is actually a set of 3 rings... a goldish colored wavey ring that has two really thin little rings that go on either side of it...
thanks guys. hey how much do i have to gap the rings... what should they be set at... with a feeler gauge
these two statements lead me to believe that you're trying to check ring gap with the rings installed on the pistons. i'm sure that you know that your supposed to check ring gap with the ring in the cylinder bore without the piston, right?
Old Apr 13, 2008 | 01:42 PM
red_line_cobalt's Avatar
i konw, thats what i was doing...
Old Apr 13, 2008 | 06:04 PM
selfinfliction's Avatar
we actually left the block in the car... removed the oil pan to on bolt the connecting rods from the crank shaft, then took off the head, and pulled the pistons.
with removing the head u will have to do the propor things to take it off. it not just on bolt and lift.. u will have a lot to remove and un hook
blocks should always be bored to fit forged pistons, the ra specs of the pistons walls for forged aren't going to be close, and it removes any irregularities of the bore.
if you're going through that much trouble, spend a few hundred extra and get the block machined
Old Apr 18, 2008 | 09:43 PM
Shanman's Avatar
yea the piston is going to be the same diameter so it'll fit the bore, u should still check it with a micrometer and make sure
i hope u have it together by now damn let a craka know
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Stuff
Oct 1, 2015 05:47 PM
Tupp
Sep 30, 2015 08:18 PM
