Question...
Old Aug 6, 2008 | 01:13 AM
BlackSSNick's Avatar
Question...
I just ordered some black 1st gen halo headlights. I want to get an HID kit for them before I install them, what do I need?
Old Aug 6, 2008 | 01:17 AM
cblt12's Avatar
i think you just need to notch out the plastic where the bulb goes in for the hid return. im not positive but im sure someone else will help me out.
Old Aug 6, 2008 | 01:20 AM
i know nothing about hid lighting, so if someone could gice me a run down of what I need and how to do it that would be great.
Old Aug 6, 2008 | 06:13 AM
chad463's Avatar
Yah everything is plug and play. I bought my set off a vendor on the site. The only thing you have to do is drill in your projector where the bulb goes so your new bulb will fit. All the wiring is just plug and play.
Old Aug 6, 2008 | 09:00 AM
what vendor did you buy from?
Old Aug 6, 2008 | 02:46 PM
EatonTVS07's Avatar
i have hids on mine i just dremeled out the holes for the lights a little to fit the bulb in after that its just a matter of following the directions, i reccomend 3b spec there great
Old Aug 6, 2008 | 06:13 PM
thats what I was thinking 3b spec, but like what wattage ballasts and what bulbs do I need for first gen projectors? I think they are H1's but are there two differant bulbs for high beams in the projectors, i'd imagine.
Old Aug 6, 2008 | 06:16 PM
chad463's Avatar
yah I got mine from 3bspec. Your high beams are seperate from your lows so even though you have HID's your going to keep your high beams. Your bulbs are H1 and I went with the regular wattage ballast.
Old Aug 6, 2008 | 06:58 PM
EatonTVS07's Avatar
you need h1 bulbs which fit in both high and low and 35w ballast will be fine
Old Aug 7, 2008 | 01:53 AM
thanks for the information guys
will the high beams be HID or no?
Old Aug 7, 2008 | 05:14 AM
EatonTVS07's Avatar
not unless you get another kit for em
Old Aug 7, 2008 | 10:05 AM
this is all plug n play?
Old Aug 7, 2008 | 01:58 PM
EatonTVS07's Avatar
if you order the kit from 3b cause you need a diff wire harness since there not stock head lights just make sure to order there mix match set
Old Aug 8, 2008 | 11:20 AM
so I'd order the bulb type for the aftermarket bulbs, and then order a 9007 harness because thats what the stock headlight harness is?
Old Aug 8, 2008 | 07:16 PM
EatonTVS07's Avatar
yes sir that is correct
Turbo Johnny
Feb 21, 2019 09:41 AM
tREBs
Jul 15, 2007 11:45 PM
steddy2112
Feb 19, 2007 11:49 PM
fifasf
Apr 21, 2005 12:42 PM
