Question on 2.8 with current Mods.
Ok, So I have been searching for about an hour now reading all I can on the 2.8 pulley. My current mods are in my sig. My question is this, will the GMPP extruded manifold be fine to use with a 2.8? Also I have GM stg 2, so do I need any other hubs or belts with a 2.8, I dont believe I do from what I am reading since I am stage 2. So with my current mods, I am thinking all I need is;
1. 60's
2. the harness for injectors
3. front mount he
4. option B
From what I have been reading I think this is what I need with my setup, minimum.
Thanks guys/gals
1. 60's
3. front mount he
4. option B
Thanks guys/gals
Looks like you have everything figured out pretty well. You can use the belt and hub you have and it will be fine to run that header, although a better header will benefit you. I would pick up a downpipe as well
not for me...i have an 08 ss/tc... this kid i know tried telling me he will be over 300whp with a 2.8 pulley, stage 2 injectors, exhaust and intake...just trying to prove a point, anybody have an idea of what the numbers would be like?
Probably around 240-250whp depending on the tune. He would most likely run out of fuel in the high rpm's though
lmao tell your friend to sign up on here and say that. that would be an epic thread.
and to OP you have it figured out just fine. get those mods on and your 2.8 and enjoy
Sl0wbaltSS
Nov 21, 2018 11:11 PM
