Question
Old Jun 8, 2013 | 04:50 PM
Sully84's Avatar
Question
simple question really, why is my 07 cobalt ss sc making 14psi of boost with stock pulley?
everything i read says my car should only be making 12 psi and to top it off i just had the sc replaced under warranty. im a lil confused with this. 14psi is where it maxes out at rev limit. had the car for 2 years and its always been like this.
Old Jun 8, 2013 | 04:52 PM
SlowBalt_06's Avatar
are there bolts holding the pulley on?
Old Jun 8, 2013 | 05:11 PM
BankerBalt's Avatar
Depends on altitude and weather too
Boost gauge COULD be off
Old Jun 8, 2013 | 05:57 PM
Sharkey's Avatar
boost gauge could be slightly off, cat could be a slight bit clogged. that or you just have a factory freak.
Old Jun 8, 2013 | 07:11 PM
Sully84's Avatar
swapped boost gauge and just put in a new header and downpipe with high flow cat. no bolts hold the sc pulley on. entire sc has been replaced. i bought this car used. 70-80 degree day it makes 14 psi and on a cold day sub 50 it makes 15ish psi.
edit: im not that far above sea level.
Old Jun 8, 2013 | 10:28 PM
silvercharged's Avatar
Wouldnt the stock tune bleed off boost after 12 if not tuned? Maybe it was tuned and returned to stock before purchase. I thought cat until i read more.
Old Jun 8, 2013 | 10:31 PM
SlowCobaltSS's Avatar
What kind of boost were you seeing before the SC was replaced under warranty
Old Jun 8, 2013 | 10:36 PM
BankerBalt's Avatar
Boost from a supercharger doesn't bleed off
Old Jun 8, 2013 | 10:43 PM
If it doeant bleed off whats the bypass valve for? Bypasses boost. Aka i meant that but said bleed.
Old Jun 9, 2013 | 10:21 AM
Sully84's Avatar
same boost with the old sc. got it replaced because it sounded rough (like marbles in the snout) and the techs at the dealer just agreed with me. lol.
i to thought the boost was limited at 12psi.
Old Jun 9, 2013 | 10:46 AM
mrbelvedere's Avatar
if someone has messed witht the tune and being close to sea level you would see more
Old Jun 9, 2013 | 06:41 PM
Sully84's Avatar
alright, thanks guys.
if you feel like answering 1 more.....
is it normal that my water temp is a couple degrees higher now that i installed a header and downpipe?
im thinking due to increased engine bay temp as a result of no more heat shield.
Old Jun 9, 2013 | 09:55 PM
I too have had the temp go u a couple degrees with header install. Id say normal there as i have no leaks or loss of fluid.
Old Jun 10, 2013 | 09:11 AM
Sully84's Avatar
alright, thats all i had. thanks for the input guys.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
