question about coolant
Old Oct 25, 2010 | 01:30 AM
Ting-ting's Avatar
so i replaced the thermostat and filled up the coolant and bleed the system but when i turn off my car the coolant hose that goes over the supercharger goes empty and has no coolant in it. so my question is is that normal or do i still have air in my system
thanks for advice
Old Oct 25, 2010 | 01:35 AM
RooTBeeR's Avatar
if its fully bled i would think that means no air pockets/bubbles in the system
Old Oct 25, 2010 | 01:37 AM
Ting-ting's Avatar
yea i did a bleed twice car on heater full blast for like 40 min each
but when i turn it off that one hose goes empty
Old Oct 25, 2010 | 01:35 PM
insylem's Avatar
If your looseing coolant out of that hose, then you probably still have air in the system. It'll have air, or coolant in it, or the atmosphere of the earth will crush it.
Old Oct 25, 2010 | 02:12 PM
Ting-ting's Avatar
this car is a pain in the ass lol
Old Nov 4, 2010 | 01:52 AM
Ting-ting's Avatar
replaced the thermo and new coolant now my temp just jumps around
one second it will be 173 then bam 189 then bam 193 then bam 173 so maybe bad sensor cause theres now way it changes that fast
Old Nov 4, 2010 | 08:42 AM
laser_racer's Avatar
Well it can change that fast it depends on how long the cars been running cause the thermostat does open and close as it gets hotter and colder. One second you have cold coolant sitting there then it opens and slams shut real fast. The only way to truliey get all the air our is use a vacuum system on the car and let it suck all the coolant back in to it. There's a few other way but I won't be going in to detail about that.
Old Nov 4, 2010 | 10:04 AM
383_Stroker's Avatar
Air in the system
Old Nov 4, 2010 | 12:33 PM
Ting-ting's Avatar
Yea i tried to.get all.air out but no luck
brandon04
Oct 21, 2015 07:04 AM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
