question about this pulley
I've got stage 2
if i buy this pulley is all i gotta do is remove the 4 screws on the one thats currently there and screw on the new one? no need for any other special equipment or nothing?
Cobalt & Ion ---> ZZ Performance
I really wouldnt go any lower in size without a tune.Your adding more air volume with the smaller pulley and not telling the ECU to match it with fuel.Im sure theres a specific size you can go down to and get away with it but I wouldnt.Thats just me though.
fair enough, maybe i'll hold off then, save up for a tune thx man!
I know the stock pulleys are pressed on, just thought the GM and aftermarket pulley/hubs were tight enough on the supercharger snout that you need some sort of tool to remove them. I might be wrong though
But as stated above, definitely wait until you can get tuned as well. With a drop down in pulley size, any small gains in power will be negated by the extra knock,heat generated and extra power robbed from spinning the pulley faster. Thats just my opinion.
ok, maybe its the hub ur thinking of? i dunno just looks like the screws are holding it in place to me :P
If you have the pressed on GMS2 pulley then youll need a pulley puller.If GM was smart and put the GMS2 hub on with the pulley(4 screws) then your good,no extra tools.
