Question about smaller pulley.
Old Jun 6, 2009 | 07:24 PM
guillermo's Avatar
I have a stage 2 on my SS.
I just ordered a 2.8 size pulley I need to know if I can use the same belt or do I need to buy a saller belt to fit the 2.8 pully.
Old Jun 6, 2009 | 07:26 PM
revolution607@yahoo.'s Avatar
if your using a shortened belt with your stage 2 already then youll be fine
Old Jun 6, 2009 | 07:29 PM
guillermo's Avatar
do you think that the 2.8 size pulley will make a difference?
Old Jun 6, 2009 | 07:31 PM
if your talking about making a difference in power, yes it will. just make sure you get tuned after you put on the pulley. and you might wanna think about colling mods if you dont have any already
Old Jun 6, 2009 | 07:36 PM
Perfect.disguise's Avatar
There was a thread somewhere what showed a Stage 2 car with no cooling mods with the 3.06, 2.9, and to 2.8 on a dyno. If I remember right the 2.8 actually made the least amount of power due to the heat and it had crazy IDC's.
Old Jun 6, 2009 | 07:38 PM
Bika's Avatar
Fail Less.
you need cooling mods, and either bigger injectors or water/meth injection
HunterKiller89's Avatar
get 60lb injectors and some cooling mods
Old Jun 6, 2009 | 07:39 PM
yea dont forget the injectors, and meth would be your best bet for cooling
Old Jun 6, 2009 | 07:51 PM
guillermo's Avatar
okay I'm knew at this so how does the water/meth injection work?
Old Jun 6, 2009 | 08:19 PM
nicksredline's Avatar
injects into ur intake or into a spacer plate and alows u to run more timing with less knock and also cools ur car down... google devils own methanol kit... ule find it
Old Jun 6, 2009 | 08:28 PM
guillermo's Avatar
cool thanks
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
