Question about the SS S/C engine
Old Jul 26, 2007 | 12:18 AM
Onyx Dragon's Avatar
Hey. I understand you guys come stock with a intercooler? Is this true? If so, is it possible to get some pics of it and where it mounts up? I am working on an idea for my GTP (since GM thought it would be a good idea to not IC it...ever...other than the GNs...BRILLIANT!) and if it looks even close to something that's doable, I might start looking for wrecked SS S/Cs in a junkyard. Long shot, I know, but might be worth it in the long run. Especially since they want a crap ton of money for an IC for these cars, and the ones that aren't real expensive are shortstack, not FM.
Old Jul 26, 2007 | 12:22 AM
Doc's Avatar
Doc
look under the supercharger here...link
its in the intake manifold and has an external heat exchanger and pump.
Old Jul 26, 2007 | 12:25 AM
silversccoupe's Avatar
Actually I would consider it an air to water after cooler.It relies on Laminovas to cool the intake charge before entering the cylinder head.Don't think it would be practical for your particular application.
Old Jul 26, 2007 | 12:26 AM
steddy2112's Avatar
Aftercooler is another name for an intercooler
Old Jul 26, 2007 | 02:44 AM
Dang it, looks like it might be a little to difficult to try to transplant onto an L67/L32. Thanks guys
Old Jul 26, 2007 | 03:17 AM
syP's Avatar
syP
in 1996 they made a prototype Grand Prix called the GPX (no not the GXP)
It had a 3.4" pulley, was intercooled, and made 300hp.. however, that would be beating the Chevy/Pontiac V8's, the LT1 camaro and Trans am.
So they had to pull it back a little bit and make it 240hp.
BTW.. dont bother fabbing up your own intercooler
www.wbodystore.com
www.zzperformance.com
The only 2 sites you should EVER visit when it comes to grand prix's
*edit just noticed you said it was expensive?
get this though, but the full size IC for $800.. buy a modular pulley system WITH a 3.0" pulley for $800... then run low 13s ALL DAY long.
its been done on many cars. Those cars respond to mods more than the cobalt does.
Old Jul 26, 2007 | 08:17 AM
www.wbodystore.com
They don't have the FMIC for the 04's. The 04's only seem to have the SS ICs
Old Jul 26, 2007 | 10:31 AM
Omega_5's Avatar
Lots of aftercooler stuff!
http://www.zzperformance.com/grand_p...cts.php?id=139
The aftercooler may be almost $1000, but the fact that it will lower you IAT's dramatically, especially when pullied, makes that cash well spent. If you don't want to buy their aftercooler rads and pumps, you can probably search around here and the cobra sites to find cheap used parts.
Old Jul 26, 2007 | 02:11 PM
Mikey851's Avatar
Why don't you get the core and then use a cobra heat exhanger (Or any HE that would fit) and whatever pump you want?
Old Jul 26, 2007 | 05:56 PM
syP's Avatar
syP
FMIC on a roots blower???
i said FULL SIZE intercooler..
the intercooler is still between the m90 and the Lower intake manifold... with a radiator up front.
Old Jul 26, 2007 | 05:58 PM
Onyxd04Redline's Avatar
You live in virgina. You can probably get away with running the SSIC.
Old Jul 26, 2007 | 06:19 PM
Area47's Avatar
Rent me! per hour
you can do a fmic on a roots blower.
take a look at the mid 90's t-bird supercoupes.
Old Jul 26, 2007 | 06:47 PM
The GTP M90 and the Tbird M90 are different
Old Jul 26, 2007 | 06:54 PM
Area47's Avatar
Rent me! per hour
doesn't matter, same roots style. the blower on the tsc is upside down versus a grand prix.
Old Jul 26, 2007 | 07:13 PM
Yeah, the problem is the whole 04 thing. Since the short stack ICs are easier to install, they seem to focus on those. I might just break down and get a short stack, oh well.
Old Jul 26, 2007 | 07:21 PM
ItalianJoe1's Avatar
The full size won't fit under your hood?
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
