Question bout my clutch
Old Sep 10, 2007 | 04:06 PM
Qwikness's Avatar
Clutch is fine all the time unless I launch out of 1st hard. If I launch it from a dig and go full throttle when its time to shift into second I'll shift and try to go back to full throttle and she'll just sit there and rev limit like it's not engaged. Is this a common problem. Didn't do it until I got the stage 2 installed.
Old Sep 10, 2007 | 04:10 PM
SSdan's Avatar
Do a search for 'Slipping clutch'
Old Sep 10, 2007 | 04:14 PM
syP's Avatar
syP
I will tell you why it does this... mine did this too on my stock clutch.
If you spin all the way to 7k, you are REALLY NOT going ~40mph like the speedo reads, you are in reality going 25ish mph. Then, when you try to shift into 2nd, the clutch says "**** that" because you are going from 7k rpms, down to like 3k rpms (2nd gear at 25mph) Its just spinning to fast, then goes down to such a low speed.
That is the only downfall with the stock clutch, everyone just needs to learn how to drive it. you are GOLDEN if you dont roast 1st gear. Just make sure you have full traction, and rip the shifter into 2nd gear.
When i had my stock clutch, i would do that, roast the upshift, chirp 3rd gear and power shifted 4th. I just put a new clutch in because it was a killer deal
Old Sep 10, 2007 | 04:26 PM
Qwikness's Avatar
Hmm good info. Only difference is I think I was at full traction but not positive. Man I could smell that thing roasting
Old Sep 10, 2007 | 04:28 PM
Eng@RebelAutoWorxs's Avatar
sorry to thread jack
how do you like your Bully clutch? have you taken it to the track?
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
