Question for those on E.
Old Sep 6, 2011 | 09:57 PM
SatanzSS/SC's Avatar
So I've been debating back and forth if I should go E or not. My main issue just like is the fact that the closest gas station that carries E85 is almost 10 miles away. Yes its my dd, that's why I'm debating wether or not to go E. My question to those currently running on E85 is do any of you carry an extra gallon tank in the trunk in case of emergencies?! Like in case you need that extra gallon just to get you to the pump to fill up?
Old Sep 6, 2011 | 10:00 PM
09BlueBaltSS's Avatar
If thats the only station near you then I probly wouldnt do it. I have a station 1 mile and about 3.5 miles away from my normal routes that Ive found so far. What would happen if that gas stations pumps were down or they ran out of E85. You need a backup plan
Old Sep 6, 2011 | 10:01 PM
Phyrric's Avatar
I wish I had E85 10 miles from me
Old Sep 6, 2011 | 10:12 PM
Well apparently I have 1 that is 7mi from me and 2 more that are both 12mi away.
Old Sep 7, 2011 | 12:50 AM
TonyTuna's Avatar
Im on E and have 2 stations near me both are 25 miles away. I usually ration my fuel every 2 weeks or so ill head to one of them fill up the car and fill up 3 5gal containers (15gal) and throw em in the trunk and drop em off at home. If your tryin to go far you gotta plan your trips around the available stations (bringin a 5gal container helps), or just take another car .
The PRICE for Ethanol (At least in my neck of the woods in CAL)
Old Sep 7, 2011 | 12:58 AM
I was wondering if anyone actually drives around with a spare tank in the trunk all the time . Figured it would be a good idea for those who aren't lucky enough to have E close enough to them. In case you're running low and need that extra gallon or 2 to get you to the nearest pump to fill up.
Old Sep 7, 2011 | 01:02 AM
SlowCobaltSS's Avatar
I basically asked the same question that your asking right now.And the answer that I got was is your tuned for E85 and you get low on gas and your not close to a station that sells it just put 5-6 gallons of 91 in your going to just cruise to the gas station that sells the E85 just dont go WOT with only the 91 in the car.
And the answer to your other question is probably no I dont think that people cruise around town with E85 in a gas can in thier trunk
Old Sep 7, 2011 | 01:08 AM
08ssedan's Avatar
I dont carry extra in the trunk, just if i were to go on a long roadtrip i would or id get retuned to avoid the hassle.
I've gotten mixed info on that from everything I've read on here. Some people say its ok to run it with 91/93 octane as long as you stay out of boost and then there's those that say its not good to run anything other then E85.
Old Sep 7, 2011 | 01:11 AM
IDK I mite be wrong and if I am someone will whime in and say
But I dont think that people are running straight E85
Old Sep 7, 2011 | 01:14 AM
08ssedan's Avatar
I was, i was running out of fuel though so im on 50/50. Some people are on full e (EJ)
Old Sep 7, 2011 | 01:16 AM
Ok thanks Brandon
So I was correct well 50/50 correct
Old Sep 7, 2011 | 01:44 AM
BlackBeast!'s Avatar
I run straight e85 its beautiful no i dont carry any in the trunk i work right by 2 stations within 5 miles. 10 miles actually isnt bad AT ALL its just how bad do you want more power? Lol
Old Sep 7, 2011 | 01:56 AM
08ssedan's Avatar
He also runs out of fuel up top but doesnt want to admit it ^^^ Lol
Old Sep 7, 2011 | 01:59 AM
No i dont only when i brake boost! Lol which doesnt happen unless im racing someone i need to beat like you haha
Old Sep 7, 2011 | 02:11 AM
Tundraboarder666's Avatar
Lol I'm 50/50 as well the E helps out a lot!
Old Sep 7, 2011 | 02:15 AM
What are the advantages of 50/50 compared to straight E85?
Old Sep 7, 2011 | 02:40 AM
sick_tight's Avatar
make sure you call or visit the place with E because sometimes its listed on google maps or where ever and its a DOT or DOD gas station or is closed down.
and the benefits of a 50/50 blend is you dont need a winter tune since E85 is E70 i believe in winter and there has been issues of full E (may be worked out now but) leaning out because theres a bottle neck in the HPFP in our cars causing some people to taper off the boost in the midrange to stop if from leaning out... SO IVE HEARD! Someone can step in if im wrong but thats what ive been told because ive been interested in E for a while now.
Old Sep 7, 2011 | 05:45 AM
06SS ALL DAY's Avatar
i live in a major metropolitan city and there is only 1 PUMP! for some ******* reason idk y. all these flex fuel cars on the road that cant use it. wtf is that about?!
Old Sep 7, 2011 | 06:12 AM
donkeyballs's Avatar
I always had 1gal of E at all times in my car just in case. You should be able to run full E with a good tune cause I almost got away with it with the bigger turbo.
Old Sep 7, 2011 | 03:49 PM
VapeWI's Avatar
Anyone need any glowsticks?
Old Sep 7, 2011 | 04:05 PM
You still get the benefits of E with the benefits of better gas mileage... Obviously you have to give a little in each direction, but It's much better than one or the other.
Old Sep 7, 2011 | 06:35 PM
SuperRedSS's Avatar
It seems easier to just run meth if there would be no stations selling e-85
Old Sep 8, 2011 | 11:11 AM
uv blue's Avatar
I ran out of e once and i put a gallon of 91 in and make it to the nearest e station
Old Sep 8, 2011 | 11:20 AM
ssblackstealth's Avatar
corn gas ftw....
so your saying you dont break up up-top if you dont breakboost??
cause my car breaks up up-top as well on 100%E but i always break boosted when racing with it.....and closest staition to me is 98miles away so cant really try it again soon lol
