questions
Old Jan 23, 2010 | 04:49 PM
DEZZIE41's Avatar
questions
my car is an 06 ss sc and has 69,000KMS on it
1 when shoulf the coolant be changed?
2 what is the down fall with our front end i have a sound when im driving slow 15kmh or slower sounds idental to a blown strut like somethign loose inside of something ubut my strus are new thanks guys
Old Jan 23, 2010 | 05:07 PM
KSSMYSS's Avatar
My owners manual says it's only due every 5 yrs or 240,000km which ever comes first.
As for the sound your getting in the front, it could be a strut mount, sway bar end link, maybe control arm bushing or even axle.
Old Jan 23, 2010 | 05:14 PM
unijabnx2000's Avatar
mine says 100k miles not every 150k
Old Jan 23, 2010 | 06:20 PM
DEZZIE41's Avatar
the struts are new all the way around the sawy bars are tight
Old Jan 23, 2010 | 08:04 PM
G11's Avatar
G11
is it a grinding noise? if so check your bearings...
Old Jan 23, 2010 | 08:38 PM
DEZZIE41's Avatar
no not grinding say for example u put a glass inside of a glass and u get the slope play its the same idea with the noise
Old Jan 23, 2010 | 09:01 PM
roboticfister's Avatar
Double check your torque on the top strut mounts. If the sway links are good check the joint on the bottom of the hub, and also the A-arm bushings, front and back. I do it with a 3ft pry bar... I put positive and negative pressure on them to check for play... they'll move a little bit naturally but if they're bad, they'll move without deformation of the rubber. These things can be hard to nail down but when you finally figure it out it's a relief!
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
