Questions about coolant temps
Old Jul 5, 2008 | 11:23 AM
MadboostSS's Avatar
what should the coolant gauge read if im running all cooling mods, meth, dual plate, and H/E??? cuz mines reading 180 to 205 sometimes.. is there anyway to figure out what my coolant is temp wise?? cuz i put my hand in the coolant and its warm. any help would be great!
Old Jul 5, 2008 | 11:29 AM
an0malous's Avatar
your cooling mods have nothing to do with your engine coolant temp.
your cooling mods change your IAT2 temps, which you can monitor with an interceptor, or hptuners.
Old Jul 5, 2008 | 11:43 AM
MadboostSS's Avatar
Oh well im just alittle scared cuz the temps are so high and i dont want to burn anything inside the engine
Old Jul 5, 2008 | 11:49 AM
D4u2s0t's Avatar
those temps are not high at all. anything under around 230 is considered normal runnint temp. i wouldn't be worried untill you get over 230-240. anything under that is fine.
also, it's normal for the temp to skyrocket in traffic, or when idling. again, nothing to worry about. the cooling system in the cobalt is based on movement. once you start moving again it should go back down.
and never open your coolant hot, it's under pressure, and you're lucky you didn't get a volcano eruption of super hot coolant in the face.
Old Jul 5, 2008 | 11:51 AM
MadboostSS's Avatar
i open it real slow and its not hot coolant its just warm so im guessing all the cooling mods i have are working right.
Old Jul 5, 2008 | 11:59 AM
UmeNNis's Avatar
Nothing to worry about at those levels
Old Jul 5, 2008 | 01:21 PM
an0malous's Avatar
which coolant tank are you opening....
we have 2 coolant resevoirs.
the main big one up near your PCM, is your engine coolant.
it has nothing whatsoever to do with your cooling mods.
this is also the one that will read temp on your DIC
the other is a small T-neck just in front of your blower,
THATS the one that will be affected by your cooling mods....
and it is NOT able to be read by your car....
Old Jul 5, 2008 | 06:01 PM
thatotherguy's Avatar
Yes the one in front of the blower
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
