Quick Pulley question!
Old Apr 29, 2012 | 06:13 PM
CelphTitled's Avatar
I want to know if it is safe to drop pulley size. I have a 2006 ss/sc and have GM Stage 2. 42lbs,injen cai,and bad mab header, 3'' zzp dp, and 3'' all the way back. I want to drop pulley to a 2.9. and I live in San Diego and only have 91 octane. I will also get a zzp pcm tune.
Please let me know... Thanks
Old Apr 29, 2012 | 06:18 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
I'm curious if the injectors can handle the fuel needed for the 2.9, my guess would be yes.
To go from a GM pulley to a 2.9, you're going to have to do a hub swap on the supercharger.
bluebalt07's Avatar
Should be fine but don't get the ZZP tune. It is just a canned tune and will require 93 octane. Just buy the pulley and get a trifecta or hp tune and specify that you will be running 91
Old Apr 29, 2012 | 06:19 PM
oh, and I miss San Diego.. Send me some of that sun to Germany, please and thanks
Old Apr 29, 2012 | 06:54 PM
carstedt's Avatar
u should be fine i ran 42's witha 2.9 for awhile..its all depending on the tune tho
Old Apr 29, 2012 | 07:09 PM
thedude411's Avatar
If hes a GM stage 2 he already has a hub. Zzp sells pulleys for the GM stage hub. No need to do a hub swap
Old Apr 30, 2012 | 12:01 PM
What if i dont do a tune right away???
Old Apr 30, 2012 | 01:01 PM
insylem's Avatar
if you donjt tune right away you SHOULD be okay.... might get a CEL though
Old Apr 30, 2012 | 10:39 PM
bluebalt07's Avatar
Should be ok. Might lean out a little since you will be running more boost but as long as you don't beat up on it you will be ok
Old May 1, 2012 | 12:42 AM
car_guy_09's Avatar
wow at the answers so far...
Yes 2.9 will be fine on gm stage 2 tune, No need to retune. Dont get me wrong a re tune would probably net better gains just because the stage tune sucks but you dont NEED it. ZZP sells 2.8 and 2.9 pulleys for your stage 2 hub, just unbolt it and bolt this one up. By the way im currently running a zzp 2.9 on my gm stage 2 with no issues and it woke my car up
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
patooyee
Oct 15, 2015 05:11 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
