quick question
Old May 23, 2013 | 12:11 AM
SalvageBaltSS's Avatar
quick question
well quick question, will lnf tranny mounts work on a lsj, and would they be better?
Old May 23, 2013 | 12:20 AM
The rear lnf mount does what the spacer does that ottp and powell sells, which is to rotate the engine. Im running one. Idk if changing the bushing in it would be good or even an option but it is different than the lsj.
As fir the front mount no idea just get a powell
Old May 23, 2013 | 12:29 AM
haha thanks!
Old May 23, 2013 | 12:32 AM
No wheel hop for me on that setup btw
Old May 23, 2013 | 12:42 AM
sweet, when i change out the tranny out, hope to get the lnf mounts off a local guy , so there probaly better lol
Old May 23, 2013 | 07:58 AM
Josh@ottp's Avatar
Actually the lnf mount offers no rotation of the engine/trans.
Old May 23, 2013 | 08:05 AM
Staged07SS's Avatar
Administrator
Administrator
Incorrect.
The SS/TC mounts do not provide any rotation. You still need the spacer installed. They are a stiffer/better designed mount than found on the SS/SC though.
That's why I opted for my genuine PRS rotated trans mount with SS/TC rear mount.
Old May 23, 2013 | 08:25 AM
mexi_loco's Avatar
The lnf mounts are what GM offers as a wheel hop kit to LSJ's. I believe.
Old May 23, 2013 | 08:32 AM
Staged07SS's Avatar
Administrator
Administrator
Correct. Along with beefier axles.
Although, the kit still does not correct the problem like Powell's rotated mount.
Old May 23, 2013 | 08:37 AM
mexi_loco's Avatar
I wouldn't know personally about that. Although, it does answer if the lnf mounts will fit on an LSJ.
Old May 23, 2013 | 08:40 AM
Staged07SS's Avatar
Administrator
Administrator
Yes, they are a direct swap.
OP, check out Crate Engine Depot. They offer the SS/TC mounts.
Old May 23, 2013 | 09:08 AM
mexi_loco's Avatar
here you go OP....you must have caught me in rare form
Cobalt Axles and Axle Kits
Old May 23, 2013 | 09:13 AM
mrbelvedere's Avatar
powell or ottp mounts are a better choice
Old May 23, 2013 | 09:15 AM
what axles are those anyways
Old May 23, 2013 | 09:29 AM
Staged07SS's Avatar
Administrator
Administrator
OP, here are just the mounts:
Cobalt SS TC LNF Trans Mount Front 20814994
Cobalt SS TC LNF MU3 Trans Mount Rear 20814995
Your best option/setup would be to purchase the rotated S1 trans mount from Powell, and run a rear SS/TC mount. While the SS/TC mounts alone will provide improved shift feel, and "less" wheel hop, they still do not correct the underlying issue. That's where Powell's rotated trans mount comes in to play.
Old May 23, 2013 | 06:09 PM
okay thanks guys, im buying used off a local guy.
Old May 23, 2013 | 08:28 PM
@ riceburner, does the lnf rear tranny mount have a crack in it? cause people say that they crack, but its still fine?
Old May 23, 2013 | 11:38 PM
bought mine today for $20 bucks? good deal ? im gonna paint them gloss black, with base an clear
Old May 24, 2013 | 07:09 AM
Staged07SS's Avatar
Administrator
Administrator
Yes. Good deal.
Old May 24, 2013 | 11:17 PM
got them painted.
Old May 24, 2013 | 11:19 PM
so what front mount should I go with if I don't run the stock tc one, and from who should I buy it from?
Old May 24, 2013 | 11:29 PM
c130aviator's Avatar
I am running OTTP mounts (stage 2) got them on a black friday sale I think. Anyway, I have been running them since February with very good results, nice clean tires spin and no wheel hop. Car has very little vibes even with BSDeletes and love them. I am running the voided design stage 2.
Old May 24, 2013 | 11:32 PM
okay, if only I could find a used set, or atleast a front stage 2 mount, lol im trying to buy all these parts at once, but just isn't working lol ( tranny mounts, powell hardcore rear sway bar, drag radials, etc) lol trying to get it ready to run some good times at the track this summer
Old May 28, 2013 | 07:18 AM
Staged07SS's Avatar
Administrator
Administrator
The front mount in the S2 rotated trans mounts is the same as S1.
What makes them S2 is the addition of a rear mount with a stiffer bushing. The rotation is the same.
That's why I always recommend a Powell S1 trans mount & SS/TC rear mount.
Old May 28, 2013 | 06:25 PM
alrighty. thanks!
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
