Quick Question please
Old Jun 24, 2006 | 06:03 PM
JCswoosher2's Avatar
Whewn after installing the pulley. how do u get it under the belt when re installing the supercharger?
Old Jun 24, 2006 | 06:08 PM
Chevypowered's Avatar
How do you get the belt back on? you have to release the tensioner arm and the belt will be come loose. Do you have the stock tensioner?
Old Jun 24, 2006 | 06:10 PM
yes i do
Old Jun 24, 2006 | 06:11 PM
tensioner arm? as in the silver rod under the tensioner?
its loosened but it can not be moved out of the way becasue of the belt
Old Jun 24, 2006 | 06:12 PM
reqalease it or take it off? because if we loosen it down. wont that bring the tensioner over the whole we need to put it back on?
Old Jun 24, 2006 | 06:16 PM
Joewit's Avatar
I took the SC pulley off and then put the belt around it and pulled the pulley with the belt on it onto the hub
Old Jun 24, 2006 | 06:17 PM
On the stock tensioner are there is a square piece on top to fit a wrench onto and you crank the whole thing clockwise i believe. That takes the tension off of the belt so all you have to do is slide it on the SC pulley.
You just release it, the spring deal under it is what puts tension on it.
Old Jun 24, 2006 | 06:18 PM
Iceblue06SS's Avatar
bolt the supercharger in place first. then there is a 15mm square part on the back of the
tensioner. put the wrench on it and roll it toward the back of the car. that pushes the
tensioner down allowing the belt to go on
Old Jun 24, 2006 | 06:22 PM
ok. im going to go try it
Old Jun 24, 2006 | 06:28 PM
ok so far. we put the silver rod thing under it back on. we r gettting a crow bar to pry down the tensioner
Old Jun 24, 2006 | 06:31 PM
use a wrench is so much easier, didn't you read?
15mm wrench is all you need
Old Jun 24, 2006 | 06:37 PM
ok everyone. thank you so much. i got it on finally.....
Old Jun 24, 2006 | 06:39 PM
sweet enjoy
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
