quick yes or no quesiton
Old Jun 11, 2010 | 01:12 PM
blackss2.0's Avatar
I'm going to be installing a zzp catless downpipe. Can I reuse the stock manifold to downpipe gasket??
Old Jun 11, 2010 | 01:20 PM
footb142's Avatar
you shouldnt reuse the gasket cause u will have an exhaust leak garanteed
Old Jun 11, 2010 | 01:23 PM
Staged07SS's Avatar
Administrator
Administrator
Depends how old the gasket is. When I had the ZZP downpipe the gasket they supplied was crappy, and fell apart from the heat which ended up causing a leak. The stock GM gasket is much better. So OP, if your gasket looks to be in good shape you should have no problem using it again.
Def. buy a new GM gasket if you are going to change the gasket.
Old Jun 11, 2010 | 01:28 PM
blackss2.0's Avatar
I saw on another thread that the 2.2 engine has the same gasket and was available at auto stores. Is this true?
Old Jun 11, 2010 | 01:32 PM
Staged07SS's Avatar
Administrator
Administrator
I'm not sure on that one. I tried to get gaskets for my downpipe at Autozone & other parts stores, but no one had any. I just went to the dealer and got a new one. It was like $8 I think. You will need a new gasket (def) for the 2-bolt downpipe to catback connection flange. That is the gasket where both of my aftermarket downpipes leaked from. I would suggest a Remflex gasket for that.
Old Jun 11, 2010 | 01:37 PM
Adam84's Avatar
Depends on how many miles is on your car, I reused mine and it is not leaking but mine was done at about 1500 miles though. For how easy it is to take it off just reuse your old one and see what happens.
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Tdubbs
Oct 13, 2015 02:31 PM
The Rookie24
Sep 20, 2015 04:33 PM
toledobalt
Sep 2, 2015 01:19 PM
