Qustion regarding install on Wideband
Old Jul 19, 2011 | 03:51 PM
hektik23's Avatar
Hey folks,
I had a quick question regarding a Wideband install I'm doing this weekend. I've used the Search function a bit and found some good info, however some seems conflicting. I don't have *too* much time to continue searching while at work, as "the man" is watching. I currently have an Interceptor installed and have tapped into the stock boost gauge for power. Am I also able to tap the WB into the boost gauge for power too and run both the WB and Interceptor off of it? I've read about the add-a-fuse option too, however tapping into boost seems a lot easier. Any help is appreciated...thanks!
Old Jul 19, 2011 | 03:57 PM
Tstonee's Avatar
Sub'd because I have a wideband sitting next to me and an interceptor on the delivery track as we speak. Really need to know1
Old Jul 19, 2011 | 04:23 PM
dannysauer's Avatar
I would just do the add a fuse maybe a little more time but safer rather blow a fuse then the gauge man
Old Jul 19, 2011 | 05:50 PM
SCcobaltSS's Avatar
All depends on the amp draw of all the gauges together vs. the fuse size. Add a fuse is easy, just do it that way with the fuse block in the cabin.
Old Jul 19, 2011 | 07:27 PM
Tstonee's Avatar
Would it work if I tapped my wideband into my stock boost gauge and my interceptor into my aftermarket headunit? I'm trying to stay away from the fuse box.
Thanks
Old Jul 19, 2011 | 08:31 PM
blake05SS's Avatar
run a power and ground to ur ign fuse put the ground on the ground bolt right of the fusebox
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
n20saturn
Sep 30, 2015 12:26 AM
