R.A.W. Meth Kit
Old Feb 24, 2009 | 03:26 PM
blownredSS's Avatar
R.A.W. Meth Kit
Just looking at R.A.W. site and I noticed their meth kit comes with a spacer which goes under the SC where the spray comes out. Sees logical, but does the meth really cause corrosion of the SC? Is this setup much better? Anyone have one?
Old Feb 24, 2009 | 03:35 PM
ShortStack's Avatar
So far, meth hasnt shown ANY corrosion of the supercharger...
Although, its been said that its better to cool a charger after it has been compressed, rather than cooling while compressing.
Old Feb 24, 2009 | 04:49 PM
blownredSS's Avatar
I wonder if the nozzles would cause an air leak affecting the boost pressure?
Old Feb 24, 2009 | 10:16 PM
Mattman6's Avatar
what are you talking about? How would it cause an air leak?
Old Feb 24, 2009 | 10:24 PM
HunterKiller89's Avatar
i think hes referring to the boost pressures inside the manifold pushing air through the meth line instead of meth flowing the other direction
Old Feb 25, 2009 | 02:42 AM
HOT CARLS SS's Avatar
There is no air leaks....I have been running this kit for 2yrs and its awesome I run 24degrees of timing with no knock. You want too spray meth after the blower instead of before...its simple you want too cool after the blower compresses the air and heats it up not during the compression...Like I said its a awesome kit and Ive had no problems...
Old Feb 25, 2009 | 10:13 PM
blownredSS's Avatar
Thanks, for the info!
Old Feb 26, 2009 | 10:11 AM
Rodimus_Prime's Avatar
The only thing I would do post blower is nitrous
Old Feb 26, 2009 | 01:31 PM
Like I said when you compress air you heat it up....so shooting meth in the blower during compression doesn't make sense. You want too cool the air after its been heated. Also the RAW kit ables you too run smaller pulleys instead of useing a idler or stage 2 belt.
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
