Raise Rev Limit?
Raise Rev Limit?
Do any of the after market stage kits, either intense or the new one with rev it up motorsports,, raise our RED LINE?
Just wondering. I find it really easy to find my current limiter.
2006 Laser Blue Met SS SC
Your current engine rev limit is set by your valve springs. Anything faster then 6500 RPM will result in float. There is good news however. Replacing valve springs on our engines is not an expensive job. The parts are a little pricey though. Bates Engineering and Ferrea make springs for us. I would go with Ferrea, as they are dual coil design, and allow for a 8000 RPM redline. You of course then have to reset your rev limiter some how to take advantge of the higher speed.
I would let a shop do it, as they will have the tools. But if you want to try it, here ya go... You don't have to take your engine apart. You remove the valve cover and spark plugs, then the cams and roller rockers. You will need an appropriate valve spring compressor for OHV engines and a spark plug hole air hose adapter. One clylinder at a time, put shop air into the cylinder via the adapter to hold the valves in place. Remove the old springs, locks and retainers with the compressor, and replace with the new ones. The GM build book will give you all the torque specs and some good pictures for reassembly.
LSX RWD S/C conversion
Originally Posted by Halfcent
Your current engine rev limit is set by your valve springs. Anything faster then 6500 RPM will result in float. There is good news however. Replacing valve springs on our engines is not an expensive job. The parts are a little pricey though. Bates Engineering and Ferrea make springs for us. I would go with Ferrea, as they are dual coil design, and allow for a 8000 RPM redline. You of course then have to reset your rev limiter some how to take advantge of the higher speed......
On an LSJ, I would say no. You already have the better valves from GM, so all you would really need is the springs. It would be cheaper and easier. Any by the way, JBP's markup on Ferrea parts is pretty high. Call Ferrea and ask for a retailer in your area and I gaurentee it will be cheaper. That's what I did.
On the L61, I would say maybe. Now you have to replace the valves, which means you have to remove the head. But since you have to remove the head, it might still be cheaper to just replace your factory valve train with Ferrea and then reinstall it. That would be kind of a personal preferrence call. In addition however, you probably wouldn't be trying to raise the RPM redline on an L61 unless you were also replacing the lower end rotating parts. So you just might have the whole engine out of the car.
yea i saw the head. Its Mucho $$$ i wanna start to upgrade internals once i have a lil more then 5K on the SS S/C but not sure on what i'm gunna be needing to up grade. Most of the reading i've done was on the 2.2 and i'm not sure what the LSJ has over the L61 on internals....
Source:http://media.gm.com/us/powertrain/en...E5)%20rev2.pdf
Yes, the build book recommends they be upgraded even on a street/strip application, but they're not going to float (at least at stock valve lifts) at 6600 or anything.
JMO
WOT
Your right, my bad. I forgot to say that faster then 6500 AND with upgraded / higher lift cams. I didn't think about it because if you go with higher lift cams, thats another reason to have to replace the springs to start with.
Actually, with the LSJ specifically, what effect if any do you think the forced induction has? Could the pressure in the induction also contribute to some float at higher RPMs?
Thanks for the brain teaser...I'll look for a paper.
Regards
WopOnTour
