Rear Badge
Old May 6, 2006 | 11:31 AM
Re4peR26's Avatar
Rear Badge
I wanted to take off the chevy sign in the back but will it leave holes or anything??? and what have u guys done to take it off..
Old May 6, 2006 | 11:49 AM
GSoccer24's Avatar
no holes. you need a heatgun or hot hairdryer and some fishing line, heat it up then skim it off with the fishing line. any goo stuck on the trunk should roll off with your fingers.
Old May 6, 2006 | 12:10 PM
BooSSted's Avatar
It's a pain in the ass but it can be done. The goo left on the trunk after you take off the badge is pretty thick and sticky. You going to need some Goo Gone or something to get all the sticky **** off
Old May 6, 2006 | 12:11 PM
cavy9psi's Avatar
i took mine off after the sun was on it for a few hours, goofoff isnt bad just dont scrub you can get the gew off with that, then wash with soap and water in that area....
Old May 6, 2006 | 12:18 PM
Maverick's Avatar
I just did mine last weekend. I used a hair dryer to heat the badge up, and sprayed lots of goo gone. Try to get the goo gone to drip behind the badge, take dental floss and gently slide it back n forth until the badge comes off. It may take about an hour to finish it completely but its not hard, and its completely safe on the car. Once the badge pops off, the gooey stuff behind it is tough to get off, but just use your patience, goo gone, and hair dryer, and it comes off just fine. Afterwards use wash and wax the area to remove any residue. The car looks SO much better from behind now, much cleaner! Do it you won't regret it.
Old May 6, 2006 | 04:21 PM
black06ss's Avatar
i used a cotten glove with a little bit of texture and goo gone to get the goo off. it doesnt hurt thepaint and it 1000000 times easier than anything else
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Delta coupe
Sep 30, 2015 08:11 AM
